Battle Version Tie rods
Old 07-18-12, 10:15 PM
scshinobi
scshinobi's Avatar
Default Battle Version Tie rods
Thought I would share these with you guys. The inner has a 5mm spacer on it. I haven't had time to install them for review yet, once the rest of my parts are in I can give a review of how they feel compared to stock.They look great I'm hoping for some good improvements. Find them on Battle Version's site. Enjoy
Old 07-18-12, 10:21 PM
scshinobi
scshinobi's Avatar
My uploads keep failing and photobucket is down currently..... I plan on running them as measured, close to stock as possible with the inner spacer in addition.
I have new lock washer OEM for the inside but I do not plan on running them, maybe Alex could chime in on if he used them? I will try to remember and ask him before install. I plan to use red locktite and just the spacer no washer. Additional spacer for the joint side are included as well but not shown in the picture, wish this uploading wasn't
Old 07-18-12, 10:23 PM
jgdynamics
jgdynamics's Avatar
cool! please let us know how they are! i might need new tie rods soon and this might be a nice upgrade.
Old 07-18-12, 10:39 PM
boosted4.6
boosted4.6's Avatar
Alex did not use the factory lock washer. I installed these on my sc a few weeks ago. Very high quality. Use red loctight on the threads. 5mm spacer helps with a lil more angle for drifting or tighter turn radius. I have all of battle versions parts on my car. Nothing but the best quality from battle version.
http://m.youtube.com/index?desktop_u...?v=Xdcw0x_DZlY
Old 07-19-12, 06:06 AM
SaintLouSC
SaintLouSC's Avatar
Subscribed. In for a review when you get them on!
Old 07-19-12, 08:49 AM
BattleVer
BattleVer's Avatar
The easy way we found to remove the stock inners is to use a channel lock pliers or vise grip around the large part of the joint and give it one big yank to break it loose. You will notice the stock lock washer will break if you give it one good turn. Then its much easier to spin off.
For the lock washers, we don't use them when we do the install because the loads on the tie rods are in push and pull. There should be no twisting loads that would cause them to come loose. If you do have some loctight it does help but not mandatory.
The 5mm spacers go on the threads of the inner tie rods before you install them. 5mm spacers may not seem like much but you will notice a steering angle increase. Not as much as you may need to be a pro drifter, which is why moding the spindles is still important if you are planning on drifting often.
For the outer tie rods, there's 2 main things to talk about. The first one and most noticeable is the cotter pin. The cotter pin hole for some reason is set too high, so we include a couple 12mm washers that need to be placed under the nut in order for the pin to sit correctly. (we will take a pic of this soon)
Secondly is that the kit comes with additional spacers for the tie rod high. Changing the height of the tie rod will affect bumpsteer. We have tried different heights but from a drivers perspective, I did not feel a change by changing the height and would suggest running the medium size spacers on the top and bottom. (we will take a pic of this soon too)
Old 07-19-12, 11:03 AM
ArodDaLob
ArodDaLob's Avatar
saw these a couple days ago on the site. I need some of this in my life. are the inner tie rod's threading the same length as stock? (the portion that goes into the rack)
Old 07-22-12, 01:52 AM
k7q
k7q's Avatar
monkey wrench works well on taking off the inner tie rods. since the SC rack in mounted in the front of the car, it gives you more room to remove them.
https://www.clublexus.com/forums/sus...well-alot.html
Old 07-23-12, 10:06 AM
afro88
afro88's Avatar
YES!!! I needed these so bad. Will be a nice addition to my knuckles.
Old 08-03-12, 07:12 PM
MIKU*SC3
MIKU*SC3's Avatar
No update on this? I really wanna buy the inner and outer tie rods.
Old 08-04-12, 06:45 PM
RINTHAL
RINTHAL's Avatar
Just go for it! Battle version has been trailed and tested and Alex is regularly on this forum so yeah. Also it sure hell beats pricing and waiting than getting super now! and Yanack stuff from Japan. I sure wish I went bv. I will for traction links and sub frame spacers!
Old 08-07-12, 02:54 PM
MIKU*SC3
MIKU*SC3's Avatar
lol, i just got super now tie rods with spacers yesterday. If my friend didnt have them local i would have got the bver ones.
Old 08-10-12, 10:11 AM
scshinobi
scshinobi's Avatar
sorry for the delay.
measured them out according to my OEM length, re-used my boots since they looked fine and new ones are a hefty tax.....
Old 08-10-12, 10:13 AM
scshinobi
scshinobi's Avatar
I didnt know the passenger and driver side boots were different until i tried putting them on opposite ends.... heh i used the plumbers tape to mark the thread while i tightened it all together
Old 08-10-12, 10:18 AM
scshinobi
scshinobi's Avatar
I still need to bug Alex about the spacers he provided and how he used them, I am still waiting for wheel bearings to be pressed in along with my control arms back from IMI. I will try to get a drive in before August is over and thorough review. More pictures and details this evening, I still need to torque my upper control arms but wondering if having no LCA in the rear would make a difference? We are supposed to torque CA down with load but its hard to reach the rear uppers with wheels on(jack stand on hub instead), I dont have the front hubs either figured i would wait for them before torquing fronts...
Quick Reply: Battle Version Tie rods
