How to Replace 98 GS300 Brake Master Cylnder Booster Unit
Old 06-10-13, 12:15 PM
KAJmapper
KAJmapper's Avatar
I have one from an 02 for sale...pm for info
Old 03-10-14, 09:32 PM
Bigtimmy
Bigtimmy's Avatar
what do you do with do you rebuild if so how much for one
Old 03-25-15, 04:41 PM
Kefzel
Kefzel's Avatar
I recently upgraded my master cylinder to 02. My sensor from the old cylinder is bad and the connector for the new cylinder is different. I am looking for a pressure sensor for 98-00 gs300 or a conector for 02 sensor. Any help will be appreciated.
Old 03-05-17, 02:04 PM
RayRays400
RayRays400's Avatar
Default Need Help
Hey guys. Do you know if a failed master pump would cause these symptoms... the dashboard has all the lights to the abs system lit up. BRAKE VSC and others I can't remember right now. The car had been sitting not being used for over a year. I jumped it and all seems ok but brake is hard to push and has a continuous beep also. Pretty sure the battery is low on charge. And forgot to mention it's a 98 GS400. Can you guys provide some feedback.
Old 04-22-17, 07:59 AM
Ahmad87
Ahmad87's Avatar
Did you bleed or flush system first or was there any pressure that needed to be released before removing? I'm about to replace mine today and I want to make sure.
Old 06-06-17, 11:56 AM
tiguy99
tiguy99's Avatar
Hey Ahmad,
How did it go?
​​​​​​​Need to do this soon myself
Old 07-25-17, 01:38 PM
Sean628
Sean628's Avatar
Old 04-02-18, 07:16 AM
iamhippo
iamhippo's Avatar
Originally Posted by KAJmapper
if you do end up replacing your master cylinder/brake booster components can I buy the old broken ones from you ?
Please pm me
I'm looking to replace my brake master cylinder soon, are you still interested in buying the used ones? Please let me know thanks
Old 04-02-18, 02:18 PM
sakataj
sakataj's Avatar
im sure 5 years later he probably isnt
Old 04-09-18, 07:54 AM
iamhippo
iamhippo's Avatar
Yes I've notice that, it doesn't hurt to ask just in case he rebuilds them and resell the units. Just the same when you ask people's suggestions on a fix and the posts are a few years old for suggestions. Just saying.
Old 04-10-18, 09:05 PM
InkedUpEB
InkedUpEB's Avatar
anything wrong with yours?
Old 06-17-19, 01:29 PM
cheapass
cheapass's Avatar
pretty sure both my 01 lx470 and my 98 gs400 are going to need some replacements...is there any way to retrofit something that doesn't have a giant A.I genital in the way of me braking safely?
Old 06-18-19, 11:06 AM
captainva
captainva's Avatar
The Avalon booster has been swapped into the 2GS which gets rid of ABS completely from my understanding as its built into the unit. I believe that theres a DIY on that.
Sondogg
08-25-17 07:31 AM
BIG TY
04-14-14 08:18 AM
ls400beave
Suspension and Brakes
13
06-20-12 07:59 AM
ray98LexGS
13
10-27-10 12:31 PM
lex786
06-25-09 06:02 PM
Quick Reply: How to Replace 98 GS300 Brake Master Cylnder Booster Unit
