DIY: Front and rear UCA and LCA Bushings, BV Toe, Traction, Subframe and Steering
Old 04-25-12, 10:04 PM
xspsi6
xspsi6's Avatar
Originally Posted by DJVe
the only diff mounts i know of are the fsm ones.
And the xspsi6 poly diff mounts
Old 04-26-12, 08:55 PM
Skew
Skew's Avatar
Update on first page.
Originally Posted by chrisindub
Nice Falcon, a friend had one that looked very similar with four speed manual, and a BUILT 289. Small car.......... scary fast. I would race him in my '67 firebird 400, and he would just kill me.
I believe he is running a 480 with a powerglide.
http://s851.photobucket.com/albums/a...1335498475.mp4
trailer.
trailer
not real car, not driven by it's own power.
he's full of ****.
good writeup, so far. waiting to see the bver install.[/quote]
Thanx, He said he just got done getting his interior installed and didnt want to drive it because he had his son with him. I doubt he will drive it in the future seeing as though he has 5 other classics to choose from.
Originally Posted by KingPhilip
The rear upper control arms will be a pain I can guarantee you that. It's got a really really really weird bushing in it. You'll find out after you burn it out. But getting the outer metal sleeve out is the hardest part, because it only go in one way, cause the end is like mushroom shaped on to the aluminum arm. So there won't be enough part of the control arm to hold on to to press the sleeve out. What we did was chisel it a bit so the "cap" end would separate from the arm and there would be enough surface to jam it while pressing out the sleeve.
You'll understand what I'm saying once you start working on it. Good luck.
I will start the burning tommorow. Could you pm me to discuss this a little more?
I just googled this and saw your post on lextreme. how do you like them compared to the solid mounts?
Old 04-26-12, 09:40 PM
xspsi6
xspsi6's Avatar
I/quote]I just googled this and saw your post on lextreme. how do you like them compared to the solid mounts?[/QUOTE]
Really no comparision as solids are for race cars and poly gives you a great solution for road going cars and cars that see some track use as we have these in 1krwhp supras running in the single digits in the 1/4 so it really is the best of both worlds
There is a pretty big thread here with feedback on them and can also be purchased via aliga as he is a paid vendor here.
Old 06-29-12, 11:31 AM
MIKU*SC3
MIKU*SC3's Avatar
Whatever happened to this thread?
It started off good. Then it just kinda died.
Old 04-04-15, 07:24 PM
Lowlife24
Lowlife24's Avatar
Skew did you ever finish this?
Old 04-06-15, 02:42 PM
1A1
1A1's Avatar
I hope you didn't use the aluminum bushings. They are terrible.
Steve
Old 04-11-15, 08:04 PM
Kris9884
Kris9884's Avatar
This is as close as I could get on a search..
I'm about to order Drift Motions full upper/lower front/rear bushing kit but is says for 92-96 only. My gut says it's the same but will these install into my 97 the same without any modification?
http://www.driftmotion.com/Prothane-...s-p/dm3089.htm
Old 04-13-15, 12:46 PM
Kris9884
Kris9884's Avatar
Can anyone comment on this ^^^^^^^^
Old 04-14-15, 12:05 PM
davvv
davvv's Avatar
Hey kris for the 97 from what i remember theres a extra metal collar that needs to be removed from the front lower control arm. Keep searching youll find it
Old 04-16-15, 05:57 AM
megamax
megamax's Avatar
iam also doing a full suspension myself. I just finished my complete front and iam starting on my rear. I brought brand new front lca's and a prothane kit. but I couldn't push myself to burn out bushings on a set of brand new 500+ control arms.
ATLs460
RX - 1st Gen (1999-2003)
05-13-14 07:26 PM
djkevin510
Suspension and Brakes
12-07-08 04:59 PM
JAB
11-07-08 10:53 AM
gs4play
08-08-08 07:45 AM
tuninghaus
01-27-08 08:13 AM
Quick Reply: DIY: Front and rear UCA and LCA Bushings, BV Toe, Traction, Subframe and Steering
