Lowest of the Low!!! Coilovers only please!!! IS Second Gen Edition
Old 11-29-14, 08:44 PM
  #481
larryw01
larryw01's Avatar
For you 2nd gen guys that are slammed on coils, do you run into issues where the upper control arms hits/bangs the fenderwell? I know the IS300s have this problem if you're too low.
Old 11-30-14, 08:09 AM
  #482
Gville350
Gville350's Avatar
^Yep, but only on the worst potholes or bad bumps if caught going to fast over. If dead-set on being LOW, the solution is to cut a hole in the shock tower : https://www.clublexus.com/forums/gs-...wer-holes.html
Might I add to this DIY that you'll want to put a vacuum running right next to the running hole saw to catch most of those metal shavings.
Old 11-30-14, 10:55 AM
  #483
Sffd103
Fire Slayer
Sffd103's Avatar
I wouldn't do that drilling until I made sure you had that problem. I was slammed in 20's and never ran into that issue. my pics are on the early pages of this thread.
Old 11-30-14, 07:07 PM
  #484
larryw01
larryw01's Avatar
That's good to know that some owners don't have that problem. I figured that spring rates would also be an important factor. If anything, I was going to order coils with customer (higher) spring rates to make a ride stiffer to avoid that problem.
Old 11-30-14, 09:19 PM
  #485
dorkacho
dorkacho's Avatar
Originally Posted by Stainless9
Not the lowest of the low, but having AWD will do that to you
wow looks sick. are those forgestars? got more pics?
Old 12-08-14, 08:27 PM
  #486
Nixcision
Nixcision's Avatar
Hey everyone,
Im looking into buying a set of bc coils for my 250 awd, and am wondering if anyones experienced any abnormal tire wear after installing them...
Im looking into a camber kit front and rear but am unsure if its entirely necessary..
Im looking at a 3" drop, running 18x8.5 225/40/18
Old 12-09-14, 08:19 AM
  #487
rayac88
rayac88's Avatar
getting there
Old 12-12-14, 01:14 PM
  #488
massaker
massaker's Avatar
Nicely done. Looks perfect!
Originally Posted by EZwider
lowest of the low . BC coils 14k spring rates . drive height
Old 12-18-14, 05:02 PM
  #489
EZwider
EZwider's Avatar
Lowest of the low. Getting new coils soon. Need to go wayyyyy stiffer .
Attached Thumbnails Lowest of the Low!!! Coilovers only please!!! IS Second Gen Edition-img-20141218-wa0001.jpg
Old 12-18-14, 09:49 PM
  #490
Sffd103
Fire Slayer
Sffd103's Avatar
^looks good! Need more pics
Old 01-13-15, 08:13 PM
  #491
LexoticJ
LexoticJ's Avatar
definitely need more pics of that beast
Old 02-13-15, 06:19 PM
  #492
EZwider
EZwider's Avatar
Theres a company called T-Demand that makes shorter knuckles. This lowers the UCA so it doesnt hit the top.
Old 03-13-15, 04:55 AM
  #493
LexoticJ
LexoticJ's Avatar
revive this thread!!
Old 03-14-15, 07:18 AM
  #494
quick123
quick123's Avatar
If you check out my build thread, I am on shortened steering knuckles to not only go lower but to prevent the UCA from hitting the shock tower. We can make these to order, and even paint them custom colors. PM me for details and cost. And they are WAY cheaper than the ridiculous T-Demand prices...LMK
Old 03-21-15, 04:35 PM
  #495
Leowaxx
Leowaxx's Avatar
I know its off the topic but i need help. It will be my firstime dealing with coilovers .
I'm thingking to get coilovers for my 2010 is250 RWD w / 18x8.5 F & 18x9.5 R . Now I'm on H&R springs which lowered 1.5" F & 0.8 R .
I like the front lowered with a finger gap between tire & fender but the rear still lil to high ( 11/2-2 fingers gap ) .
Im running 225/40/18 F & 235/40/18 rear.
1 : If i want to buy the BCR coilovers , just buy as is or Do i need to get stiffer springs rate ?
2 : I dont know how much drop it will be if i want a finger gap between so Do i need FRONT & REAR camber kit ?
Quick Reply: Lowest of the Low!!! Coilovers only please!!! IS Second Gen Edition
