LS400 dust shields fitment and caliper decals
I will be upgrading my brakes on my SC300 soon. LS400s on the front and TT rears. At the same time I will be changing all 4 wheel bearings. Since I will have everything apart for the wheel bearing job, I might as well put on the correct dust shields as opposed to cutting them off or modifying them. Do the LS400 dust shields definitely bolt right on?
Also, where is the best place for caliper decals? I found these but not sure if I need the straight or curved ones.
http://www.ebay.com/itm/LEXUS-CURVED...item3f112dc7be
http://www.ebay.com/itm/LEXUS-STRAIG...item41604d5979
Thanks
Thanks
Straight decals usually look the best on LS400 calipers. As for the dust shield, I will be trying to do the same thing since I have my hands on LS400 dust shields and brakes. Let us know if they bolt directly onto the hub or what mods need to be done to get it done since nobody uses dust shields with LS400 brake upgrades.
Thanks for the input on the decals. Unless I hear otherwise in this thread. I'll order those shields and see how they workout and post my results on here. I got my TT brake kit this week for the rear(everything but the shields) and know those shields bolt on, the only problem is they are very expensive new. I'll prob buy them, but until I am ready to do the job in the spring I am trying to hold out for a used set.
Anyone know what size the area is the decal goes on with the LS400 calipers? The seller of those decals I posted stated they are 80mmx15mm. I dont have my calipers yet, so if someone knew, that would be one less thing I have to get later.
Thanks
Thanks
No I meant these:
I wanted them because they look like the front wil lwork with the LS400s and the rears will look nice on the TT rears as well as be a good fit.
Just bought a set of supra TT rear suspension knuckles with hubs and shields, etc. I would like to change the bearings on these, then swap the knuckles to my SC300 to avoid down time. Does anyone know if the SC300 rear knockles and TT knuckles are interchangable? They are showing different part numbers on the web, but I am curious what the difference is.
The heat shields and spare front knuckles arrived. The shields have a different bolt pattern than the stcok sc300 shields. I am going to try redrilling the LS400 shields and see how that works. I hope it does because if it doesn't, I'll be pressing the bearings out again
To wrap up this thread I did end up getting the LS400 heat shields to fit. However, it required more work than it was worth. I had to drill in a different bolt patttern on the shields, as well as cut a good portion of the shield to clearance the tie rod end. I am glad I ended up with the correct shield, and isn't horrible if you are doing your bearings at the same time, but it is probably just as good to modify and use the stock SC heat shields when just doing the LS400 upgrade alone since you have to cut and drill the LS400 shields anyway.
Yes, I could have. However, if I didn't try, who's to say they would not of been a bolt on? No one else was able to answer that question and now we know. I took a gamble on trying to have something better than a hacked up stock shield. In then end, I ended up with a hacked up LS400 shield, but at least other people going down this road will have the information available to them. I know how it is organizing these little projects and not having the info available to plan the project. I'd still rather have these shields than a modified SC shield. The LS400 shields are designed for these brakes. I really don't see what looks so funny, it is just a stock LS400 shield with a slot cut in it.
COMPLETED WITH dust shields. Nothing to see really, they look just like stock LS400 brakes. The important pic is the one showing the shields and the modification necessary to fit the shield. I have since moved on to TT brakes in the front. I was not happy with the pad selection available for LS400 brakes. The stock TT front dust shield is a bolt on too.
