Getting rid of Rubbing
Old 01-24-12, 06:03 PM
2BENVD
2BENVD's Avatar
Default Getting rid of Rubbing
Just share ways you've managed to prevent rubbing as much or none at all, whether you streched tires or removed fender liners or ect.
Old 01-26-12, 11:05 PM
2BENVD
2BENVD's Avatar
Anyone have any suggestions?
Old 01-26-12, 11:50 PM
CrazySC300
CrazySC300's Avatar
Well, Since I haven't relocated my wiring harness and have my car slammed...I put sheet metal underneath the wheel wells and so far, the rubbing hasn't been so bad every time my car bottoms out.
Old 01-27-12, 01:34 AM
levie
levie's Avatar
removed fender liners.
Old 01-27-12, 04:46 AM
afro88
afro88's Avatar
Rolled rear fenders and a slight pull. Tucked harnesses and rolled front fenders.
Old 01-27-12, 08:30 AM
2BENVD
2BENVD's Avatar
Think Vihn mentioned he did the same thing, how did you go about doing that, what did you use to secure the sheetmetal? All good suggestions guys
Old 01-27-12, 01:01 PM
poorsupra
poorsupra's Avatar
well, relocate your harness, trim the tops out of your fender liner, roll or pull your fenders as needed, or stretch your tire. thats pretty much all you need to do. it all depends on your set up. do one or do all. its not rocket science.
Old 01-27-12, 03:34 PM
CrazySC300
CrazySC300's Avatar
3M Double sided tape, That stuff is alot stronger than you think.
Old 01-27-12, 03:49 PM
MIKU*SC3
MIKU*SC3's Avatar
Smaller side walls, or hammer the **** outta that chassis part in the wheel well. Thants what i need to do soon.
Old 01-27-12, 07:59 PM
2BENVD
2BENVD's Avatar
would have never thought, thanks
Old 09-27-12, 09:33 PM
Anferny
Anferny's Avatar
I'd like to eliminate rubbing in the front while turning. I have 18x8 30 offset with 225/45/18. I know where the tire is rubbing. I want to hammer in those areas but before I do that, I would like to know if I will be damaging anything other than the chassis.
Old 09-27-12, 10:13 PM
CalitriSC
CalitriSC's Avatar
As far as the wire harness, take the time to do it the right way and relocate it. The sheet metal way has been shown not to work. The wires will get hot from the rubbing and create a nightmare, people have posted pics before. It only takes about an hour, not sure why people refuse to just do it the right way one time.
Old 09-28-12, 09:44 AM
Dv8
Dv8's Avatar
Relocating the harness takes less than an hour.
20 minutes or less if your compitent. Unplug from inside the car, feed out, tape, feed back in.
But that isn't a solution to rubbing. A big god damn hammer is.
Old 09-28-12, 11:05 AM
LameSC300
LameSC300's Avatar
^^^^^^^^^ this
nuff said
Old 09-28-12, 07:01 PM
IN2LXUAL
IN2LXUAL's Avatar
Ive relocated, rolled, stretched, just need the big damn hammer
But that isn't a solution to rubbing. A big damn hammer is.
Quick Reply: Getting rid of Rubbing
