Coilover Recommendations?
Old 02-14-12, 09:51 AM
  #61
bduboulay
bduboulay's Avatar
Originally Posted by GSteg
The twisty magic damper **** adjusts rebound. There aren't too many coilovers for the car with both rebound and compression adjustments. Far too many people will screw up their ride quality.
Custom spring rate??
It's the stiffness of the springs on the car you have the option to get a stiffer springs with BCR coils
They come standard 10k in the front and 8K in the rear for the rates. I got a custom setup with 12k in the front which is a bit stiffer. It all depends on what your going for I guess and how you drive your car!
Old 02-14-12, 11:33 AM
  #62
CircuitMS
CircuitMS's Avatar
The KW's will give a better ride when setup correctly. Meaning you would need to adjust the damping properly for your needs and have it set at a good ride height.
KW's are not meant to be lowered a lot, or slammed.
Old 02-15-12, 04:15 AM
  #63
Deezel4ny
Deezel4ny's Avatar
Thanks Sffd103, now I have to find a good price for them. I've been checking ebay, but not sure if I should trust ebay or purchase them at a local store.
Old 02-15-12, 04:25 AM
  #64
Deezel4ny
Deezel4ny's Avatar
Thanks bduboulay, I'll do a side by side comparison and see what's the difference,
Old 02-15-12, 06:54 PM
  #65
Liz3rb3rtH
Liz3rb3rtH's Avatar
I'm on buddy club d spec coils. Loooooooooooove them. I'd recommend
Old 03-02-12, 12:11 PM
  #66
bduboulay
bduboulay's Avatar
Thanks for all the help. I reset my preload and the car rides a bit softer and it's not as tight in the corners. Anyone know how hard I can set the preload cause i wouldn't mind making it stiffer.
yoondog
CL of Southern California
05-13-13 06:52 PM
RobzKar
Suspension and Brakes
05-01-13 08:31 AM
supralative
01-29-13 12:16 PM
Heyboss2JZ
IS - 1st Gen (2001-2005)
18
08-04-12 06:55 PM
jnguyenGS
15
09-04-11 01:55 PM
Quick Reply: Coilover Recommendations?
