DIY - Rear Axle Carrier (Knuckle) Bushing Replacement
#391
What socket size are you guys using to push in the UK bushing? I heard some are using 34mm and others are using 36mm? Will either work? I don't have those sizes and will need to order it from Amazon.
Thanks.
Thanks.
#393
i clicked on the link to febest but when i get to the end to order the products it just says your order is confirmed and theirs no option to pay! The only option is to go back and edit the order again?
#395
I ordered these rear knuckle bushings from ebay. the store is called japeurocarparts. the item number is 181812644335. they came from new zealand i think but I got them superfast and they look and feel like o.e. quality. I've had them on for a week and noticed a large improvement. Plus they help get you camber back in spec. by taking up the slack you lost in the excessive play. I paid about 70 for both.
Last edited by badblackgs; 02-18-16 at 06:16 PM. Reason: misspelled ebay store name.
#396
They only have 1 left in stock from that ebay store. Will an IS300 one work they have a bumch of those? http://www.ebay.com/itm/LEXUS-IS200-IS300-99-05-REAR-ARM-WHEEL-HUB-CARRIER-STUB-KNUCKLE-ROSE-BUSH-x1/171869040106?_trksid=p2047675.c100010.m2109&_trkparms=aid%3D333008%26algo%3DRIC.MBE%26ao%3D1%26asc%3D35721%26meid%3D2b8498c0f0914bccbf80c1ec62080ade%26pid%3D100010%26rk%3D1%26rkt%3D9%26sd%3D181812644335
#398
Updated ebay link
For anyone reading through the first couple pages and struggling to find the parts (I shouldve skipped to the last page ha ha), here is an updated ebay link to a seller called Japeurocarparts selling the bearing, he has two listings, one for the IS and one for the GS.
Here is the GS bearing:
http://www.ebay.com/itm/181812644335
#399
thank you so much for the update, glad i clicked to the end, i was having trouble sourcing the parts, I am currently replacing my front suspension arm #2's and have also been hearing a noise from the rear end over bumps, thought it was the ball joints at first, but found it was this bushing, I love this site, againg thanks for the link update to get the correct part
#401
First of all, Thanks for this thread! Couple of weeks ago I noticed same problems in my GS450h 2009. Sound is like brick bounces in the trunk when going over speed bumbs.
I'm not sure is it dead shock or bushing. I have lifted passenger side up and tried to shake wheel & arms, but not found any clear reason.
SO, is this carrier bushing problem only Gen2 GS problem or also Gen3 GS problem..?
If you know the correct bushing for GS450h 2009, please share the link/info. Thanks in advance!
#403
Looks like here is a current source - http://www.ebay.com/itm/181812644335?rmvSB=true
Thanks - CA car .
Thanks - CA car .
