Any Idea on what this is? HELP
i have a 98 gs and its lowered on stance GR+ coilovers. my problem that i cant figure out is when im driving and i go over a speed bump slow of course. is like my car shifts and make like clunking noises as if nothing is stable.
i am still on stock wheels. I though maybe my wheels base and them being narrow was the problem but i could see it being the problem any advice from anyone would be great.
also my lower ball joints re good along with my bushing etc. I hope i explained the well
I have the same problem but I figured out what was wrong with my car. First you're going to want to jack up one of the front corners with that wheel off the car. Grab onto the spindle part that connects to the upper ball joint and try moving it back and forth(in and out, not side to side). If there's play in it, you will feel, see, and hear the upper ball joint hitting metal. Try it out and report back.
yes i did this today and infact there is play..... i just cant figure out the rear....everything is tight suspension wise the top of the spring is touching the top of the collar there is no play in the springs at all and i lowered by using the sleeves..... that rear is killing me it sounds like a marble jiggling around when driving because the roads out here in va beach arent perfect.... so with this jigle i gues i need new upper control arms or can just the upper balljoint be replaced?
Nice to know that.
I have no idea about the rear. I haven't got that far yet since I've only had my car for 3 weeks but I'm focusing on the front end because that's just trashed. So far, I have done calipers, pads, rotors, lower ball joints, outer tie rods and still need to do upper control arms, steering rack bushings, and caster arm bushings..
I had my UCA's installed but I still have a slight clunking. Not much but some. I'm going to be doing the steering rack bushings and caster arm bushings soon. Hope that takes care of everything. If not, I'm going to move on to front shocks. I don't mind throwing the money into my car because I got it at 185k, there's no telling what has been replaced and what hasn't. I'd rather be safe than sorry.
steph88
03-13-09 06:47 AM
