Lowered IS350 AWD Anyone?
Old 02-09-12, 05:36 PM
delerium
delerium's Avatar
quick update....so far no issues at all. ride qualtity has been as good as the day these were installed.i am also running a pretty conservative drop and softer dampering. on really cold days i get an occasional clunk in the rear but i have noticed its only on really cold days. i had the same issue with the tanabe coils on my rsx. in the next couple of weeks going to rotate the tires and check the collars on the coils.
Old 02-10-12, 03:58 PM
Laid_Out
Laid_Out's Avatar
looks great. keep us posted on them
Old 02-11-12, 12:35 PM
LexStylez
LexStylez's Avatar
How low are you from the ground to the top of fender? I've been reading for AWD that 25" is a good number to go by, going lower can damage your cv boot.
Old 02-11-12, 02:02 PM
Phresh2010
Phresh2010's Avatar
you might be able to get away with 24' or 24 1/2 as i have gotten away with that all summer...just be sure to check the cv boot every now and then (way to check is i.e., if you have a garage or a parking spot before you drive off in the morning check if there is any wet spots near the 4 wheels, should be a greasy feel liquid)
Old 02-11-12, 07:51 PM
LexStylez
LexStylez's Avatar
Thanks for the tip. It scared me reading about leaked cv boots.
Old 02-11-12, 10:09 PM
pdpgps
pdpgps's Avatar
Just in case some of you guys were wondering, I had to pull out a tape measure to get an visual of what 25" clearance is. I am assuming an 18" f-sport wheel with 225/40/18 tires, so here are my approximations as denoted with the "~"
18" rim + ~40mm of tire above and below the rim (varies depends on the tire model) = ~25"
25" + 4-5 finger gap = ~28-29 inches.
This allows the user to adjust the height around to around 3-4 inches and get very close to 1 finger or less gap without any CV boot issues.
Please correct me if I'm wrong!
Old 03-16-12, 09:55 AM
delerium
delerium's Avatar
Still trucking along nicely. Have had these on and after a bit of settling I am a little under a 2 finger gap. Looking for some 18s. So might adjust the height again. I dont like to ride too low here in ny with all the pot holes. Only issue is the same clunk on cold days down steep driveways. My fsports on my old 250 did the same thing. I'm not too worried since the ride quality has not suffered.
Old 04-26-12, 05:20 PM
Dr3wSaL
Dr3wSaL's Avatar
Thanks for the post OP. I've had my 07 awd 2IS for about two weeks now and have been researching suspension as much as possible. I do worry about the vibrations because I don't want to f anything up. After reading your post I think I'm going to go with the BCs and just not drop it too low as in past 24.5 or so. I'll make sure to upload some pics and an update on how they run once I start my new job and get some bucks to put into the car. Thanks again!
Old 04-28-15, 07:43 AM
N2M
N2M's Avatar
Thanks for the post
I have the same make and model, in the first three pics, is that after the install??
i have the same stock 17s, looking to go to 19s
did you get the 18s on? any rubbing issues?
Thanks
Old 05-01-15, 11:07 AM
Nixcision
Nixcision's Avatar
just lowered my 250awd 25" fender to ground... i vibrate on inclines! enough to see the rearview mirror shake at least
Old 05-04-15, 03:20 PM
delerium
delerium's Avatar
Originally Posted by N2M
Thanks for the post
Thanks
That was after the install. You could do 19s but you may need to tweak the ride height. Was able to switch to the 18s with no issues. The ride quality did suffer over time and was really disappointed with under 10k too. I got spoiled with my tanabes on my rsx. Even the stocks with f sport springs rode better.
asrc350fs
RC - 1st Gen (2015-present)
03-24-19 07:56 PM
asapcolin
Suspension and Brakes
20
07-13-15 08:29 AM
1BadTitan
10-02-14 02:50 PM
flektone
16
12-08-10 09:34 AM
kashmoney1
06-08-10 10:50 AM
Quick Reply: Lowered IS350 AWD Anyone?
