Best quality upper control arms
Old 12-11-12, 12:49 PM
  #46
eyecon7
eyecon7's Avatar
......................eta?
Old 01-17-13, 09:50 PM
  #47
nar8ta
nar8ta's Avatar
playin games............... we need these
Old 01-18-13, 09:32 AM
  #48
FIGS
The Maker
FIGS's Avatar
trying to have camber correcting lower bushings in Feb, I am still waiting on factory samples.
Upper arms will be max negative camber arms with airbag clearance and fixed ball joint.
Mike
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old 05-16-16, 08:48 AM
  #49
lil23pinoy
lil23pinoy's Avatar
Mike
I know this is old...but is there an update on this for custom knuckles, and less stress on the upper ball joint?
Old 10-10-16, 09:50 AM
  #50
Aristo722
Aristo722's Avatar
Mike
Also, OP. Ive done option 1 and 2. I have S9 FUCAs along with T demand shorted steering knuckles. They have done me great and the geometry correction and clearance is generous, it is the most expensive option...but, however, has worked best for me.
Mike, when you're talking camber correcting with LCA bushings, you're saying that these will add + camber correct? I am in the market for more - camber for my front end, my RCAs, FUCAS, and OEM LCAs are maxed, as well as my steering knuckles, do you have anything that I can squeeze a few more degrees out of my set up? I am on the OEM FLCAs, maybe a different set of FLCAS or even bushings to add more - camber?
*Side note, my FUCAS are maxed at -5, but my steering knuckles correct +3 leaving me with -2 total in the front*
Old 10-11-16, 08:25 PM
  #51
FIGS
The Maker
FIGS's Avatar
Just a quick question on how the knuckles are correcting camber? Most interposed RCA's are camber adders because they relay the lower ball joint. Now we can make customer knuckles that are 1-P and can add negative camber, or we can modify the factory arms or we can make new lowers. Our bushings will add another 1.5 degrees.
__________________
Old 10-12-16, 07:30 AM
  #52
lexo98
lexo98's Avatar
Hey Figs,
Back to the original topic. Can you give us a review on those Mevotech upper control arms your selling on your site?
Old 10-12-16, 09:16 PM
  #53
FIGS
The Maker
FIGS's Avatar
Originally Posted by lexo98
Hey Figs,
The Mevotech arms offer a nice factory replacment with bushings and a ball joint that is representative of factory. The enhanced boot is tougher that the factory boot so it should hold up to more abuse. Other than that, they are designed to factory replacement. If you are extremely lowered or have different setup goals than stock, that is where the adjustable options come into play.
Mike
__________________
The following 2 users liked this post by FIGS:
Scorchez (02-12-24), tiguy99 (09-04-17)
Old 08-29-17, 02:46 PM
  #54
sakataj
sakataj's Avatar
i hadnt paid much attention to parts in a few years as the car was supposed to be leaving but now that its not i have been looking around again. i dont need them anymore but i see Mike's UCA are out and man they look amazing IMHO
http://shopfigs.com/v3/VIP-FUCA-GS-S...rice&order=ASC
tiguy99 (09-04-17)
JAB
RX - 1st Gen (1999-2003)
11-30-18 03:38 PM
Returd
Suspension and Brakes
06-03-17 12:47 PM
O1GS43O
06-01-10 08:34 PM
frankjames
07-20-09 09:51 AM
n737nc
02-06-07 05:42 PM
Quick Reply: Best quality upper control arms
