Best quality upper control arms
Old 08-11-11, 06:54 PM
  #31
kit cat
kit cat's Avatar
Originally Posted by FIGS
you can buy mine for $250
do you have a link?
Old 08-12-11, 08:31 PM
  #32
FIGS
The Maker
FIGS's Avatar
just limited release, so not on my site. send me a pm and I can invoice you.
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old 12-02-12, 10:39 PM
  #33
sakataj
sakataj's Avatar
J, you ever do anything about this......those Milky white UCA's are essentially the same price as the Ikeya's without having to pay the shipping from Japan so i think the Ikeya's would be a better solution for me
Old 12-03-12, 07:07 AM
  #34
FIGS
The Maker
FIGS's Avatar
We fed back of if the design changes for our arms last week and are now getting the production model quoted. It will feature a static ball joint and adjustable inner bushings, angular offset for ball joint centering at 3" drop. These will be negative camber arms only. For camber correction we will be doing this on the bottom via eccentric bushings and our comple arm replacement.
__________________
Old 12-03-12, 12:13 PM
  #35
sakataj
sakataj's Avatar
so your gonna make a LCA # 1 OR remake the LCA # 2? pics of these as im confused by the plans and how it will adjust camber
Old 12-03-12, 02:00 PM
  #36
FIGS
The Maker
FIGS's Avatar
right now it will be both combined. camber will adjust via length of the arms as well as inner eccentric bsuhings.
__________________
Old 12-03-12, 02:03 PM
  #37
sakataj
sakataj's Avatar
interesting.....so the arms will be conjoined now? would these have replaceable parts so you wouldnt have to replace the whole arm if one of the joints fails?
more importantly ETA mike?
Old 12-03-12, 03:39 PM
  #38
FIGS
The Maker
FIGS's Avatar
I am just playing with various geometries now in CAD. There will be a lot of backburner items done in Dec. Hoping to get a few parts cut soon. perhaps next week. Brian you need to figure out how much correction you really need.
The bushings may do it.
All parts of the arms would be serviceable.
__________________
Old 12-03-12, 03:44 PM
  #39
BayAreaLex
BayAreaLex's Avatar
I like option #2.
If a competent fabricator is doing the cutting/welding, the strongest point on that knuckle will be the weld. I have zero concerns about strength. I do have concerns about tire clearance however. You'd have to take some measurements.
Old 12-08-12, 10:16 PM
  #40
eyecon7
eyecon7's Avatar
Hmmm so what about the stress on the ball joint? with the correction of the LCA?
Old 12-09-12, 08:17 AM
  #41
FIGS
The Maker
FIGS's Avatar
What stress are you talking about? misalignment stress? These are very small angular changes, a few degrees, so there should not be any additional stress.
Our upper control arms will be for adding negative camber and the ball joint angle will be normalized.
__________________
Old 12-09-12, 10:24 AM
  #42
LuxuryGS3
LuxuryGS3's Avatar
Answering for Brian.. I think if we can get anywhere from 1-2 degrees of camber correction in the front about 99% of us will be more than happy.
Old 12-09-12, 07:43 PM
  #43
eyecon7
eyecon7's Avatar
Exactly I don't need more camber I want to ride low with somewhat proper fitment.
Old 12-09-12, 10:41 PM
  #44
FIGS
The Maker
FIGS's Avatar
The problem is that if you planned for proper fitment and if you correct camber on top then you end up with a tire in the fender. That is why the lower control arm bushings are more applicable to camber correction and will be what we release for that solution.
__________________
Old 12-09-12, 10:44 PM
  #45
FIGS
The Maker
FIGS's Avatar
For the LCA correction we will be reducing ball joint stress if anything because we are bring in the angle. Sorry just reread your post.
Thanks Mike
__________________
Quick Reply: Best quality upper control arms
