Rear camber adjustment
Old 07-22-11, 07:37 AM
FinLIFE
FinLIFE's Avatar
Default Rear camber adjustment
Anyone running spc rear camber bolts? Any complaints? I am thinking of getting these to correct my negative camber and they are fairly inexpensive. Id love to get figs arms, but they are way more in price and are those necessary?
Old 07-22-11, 08:36 AM
AKS14
AKS14's Avatar
I just installed them on my GS.
Install was easy, did it on a lift and it only took a maybe an hour for both sides.
Before my camber was at around -3.0 and -3.3 with stock bolts pretty maxed out, with the SPC bolts I was able to pull it out to -1.4 and -1.5.
I did have the FIGS toe arms which I installed as well, and before the toe was adjusted I was at around -1.8 but when the toe was straightened out the camber came back out a bit.
Overall I think its a pretty good solution to camber correction for the rear.
Old 07-22-11, 08:56 AM
Rick James
Rick James's Avatar
How much are spc rear camber bolts?
Old 07-22-11, 12:33 PM
AKS14
AKS14's Avatar
Pretty cheap, I can get them for about 60$ each.
Old 08-02-11, 04:08 PM
FinLIFE
FinLIFE's Avatar
hey aks14, did you have to buy two? or does one kit include one bolt for each side?
Old 08-02-11, 10:46 PM
HtownGS4
HtownGS4's Avatar
You have to order two kits for the rear camber. Found it here: http://thmotorsports.com/spc_perform.../i-398084.aspx
Just ordered my front SPC upper control arms and rear caster eccentric cams. Haven't put them on yet, but will soon. I just messaged THMotor on here. Nick was quick to respond to all PM's. Great seller. No problems.
Old 08-03-11, 08:58 AM
AKS14
AKS14's Avatar
Yea you need 2.
i2fat
Suspension and Brakes
05-11-15 03:14 PM
SprtDesign
10-13-12 05:29 PM
jnguyen87
03-14-11 06:27 AM
t70 supra
SC- 1st Gen (1992-2000)
01-18-11 08:50 PM
buffalosoj
02-09-09 10:27 AM
Quick Reply: Rear camber adjustment
