Do i really need to buy Alignment Kit for H&R lower spring?
do you know what is Alignment Kit for H&R lower spring?do i really need to buy that too?i did google and read all the post and most people said after install H&R lower spring and drive the car like 2000 miles then get alignment.what did they mean? Did they mean alignment the spring or the tires?i have after market 19 stargged and i do have free alignment at tires shop every 6000 miles.Im just confused between what did the mean alignment after install lower spring.Im sorry because its new to me.thanks anyone can help.
You dont need a camber kit for your H&R drop. Your not running aggressive wheels. With spring most people after install run it for a few weeks to let it settle. Cause once it settle the car kinda sags a bit lower. Then you get the alignment done for the correct ride height...
What do you mean get alignment to correct ride height?i was thinking to install spring myself and i jus dont know what i need to do after the car sag lower like you said.Thanks for ur help
I mean im gonna install lower spring myself.can i alignment myself too or i need to take my car to local tires shop and let them do it.do you mean alignment the tires or the spring height?
You may certainly align your car yourself. The question is, do you have the tools to measure angles? Chances are, if you are asking whether you can do alignment yourself or not, then you probably can't and won't know how to set up your car.
Alignment is alignment. There isn't one for tires or ride height. Everything needs to be taken into account before adjusting the angles.
And properly installed (and properly manufactured) springs do not settle
Direct quote from Eibachs FAQ:
Do a search on resetting the bushings correctly- folks failing to do so then having them deform after install is usually what is happening when people think their solid pieces of metal spring are somehow "settling"
You'll absolutely want an alignment after changing any suspension components though, especially springs.... and it's something I'd recommend finding a good alignment place to do properly- the main thing is you want the car to have 0 dynamic toe- that'll do more to reduce tire wear than anything else you can do on the vehicle.
Originally Posted by Eibach
All Eibach suspension coils are pre-set to eliminate settling and increase life expectancy
Here's an example of what you'd have to do to do the alignment yourself. I'd recommend taking it somewhere. And I agree, if probably installed springs will settle once sat inside or taken around a couple of corners.
http://www.elantragtclub.com/id554.html
get one, ive had mine on for about a year, and cause uneven tire wear...inside of my tires are worn almost to the steel braiding...never got it aligned. Took it to a local tire shop, and was told it was mostly my toe stance causing the wear, not the camber...can anyone confirm this? i would hate to have to buy a camber kit.
vi3t80y
Suspension and Brakes
08-05-11 07:10 PM
