Rca help???
Old 07-01-11, 08:48 PM
tither777
tither777's Avatar
Default Rca help???
i went to shop and had the rca's SAGE 40mm put on... when he went to align it he said he couldnt get it to align right because the adjustment on the lower control arm was froze..... he said they would need to replace the lower control arms for 1300... is there a way around it??? thanks
Old 07-01-11, 09:13 PM
DeanGS
DeanGS's Avatar
Go to a different alingment shop. The LCA is adjusted with a cam with a bolt running through it. Unless there was some type of damage I don't see how it could be frozen enough to warrent replacement (it may be "stuck" but a breaker bar and/or torch should be able to break it free).
Old 07-01-11, 09:31 PM
tither777
tither777's Avatar
he was saying the rubber was turning(bushing)
Old 07-01-11, 09:38 PM
DeanGS
DeanGS's Avatar
OK, the rubber turning would mean to me that it is either damaged or severely deteriorated. If that is the case then the car would not hold a proper alignment. $1300 is high to me to replace them. It is less than $200 for each and then remove sway bar end links and three bolts and you have it out. Took me less than an hour to change both of mine but I do not know what the shop rate is for changing them.
Old 07-01-11, 10:40 PM
PHML
Master Thread Closer!!
PHML's Avatar
1300 is highway robbery!! Find a new mechanic!!
Old 07-02-11, 03:41 PM
tither777
tither777's Avatar
haha.... thanks
project250
Suspension and Brakes
13
10-31-11 09:47 AM
Vincent123
14
05-21-10 03:21 PM
tomtnc
12-03-07 02:21 PM
7Cain
GS - 1st Gen (1993-1997)
08-03-06 06:10 PM
EUROJulian
07-01-04 02:19 PM
Quick Reply: Rca help???
