Brake Bleeding Question
Old 09-14-02, 01:23 AM
Kbueno
Kbueno's Avatar
Default Brake Bleeding Question
-I had a line break which caused all of the fluid to be drained from the brake fluid reservoir. After replacing the brake line and bleeding from the caliper...al seems OK. My question is should I take it to the dealer to have the ABS system bled?? I know on My Ford F-150 if the reservoir goes dry you have to take it to a dealer to bleed the ABS system (i.e. it has to be hooked up to a computer to tell it to open a bleeder valve).
Thanx in advance.
Old 09-15-02, 01:41 AM
DoubleWhoosh
DoubleWhoosh's Avatar
No need, just make sure to have the car running when you're bleeding everything.
Todd Matsubara
TM Engineering LLC
www.tmengineering.net
Old 09-15-02, 09:28 PM
Kbueno
Kbueno's Avatar
Todd Matsubara
TM Engineering LLC
-Just wanted to make sure. Thank-you for your reply!
KtIS
Suspension and Brakes
06-23-15 01:44 PM
Equalizir
11-10-14 01:09 PM
Ascari_2
IS F (2008-2014)
20
05-23-14 11:23 AM
BatKing
21
05-07-09 07:33 PM
Mr GS400
05-20-02 01:39 PM
Quick Reply: Brake Bleeding Question
