SPC Caster Arm/Camber Front & Rear kit is on (data adjustments included)
Old 06-23-11, 08:17 PM
slowdiver
slowdiver's Avatar
Default SPC Caster Arm/Camber Front & Rear kit is on (data adjustments included)
I roll on 20's with a 2" inch drop now. It's nice knowing I don't have to worry about inner tire wear anymore.
Specified Ranges below are for GS 400 '98-'00
Front Left:
Camber: Before 1.1 degrees/After -0.1 degrees
Toe: Before 0.29 degrees/After 0.1 degrees
Front Right:
Camber: Before 1.3 degrees/After 0.1 degrees
Toe: Before 0.04 degrees/After 0.1 degrees
Front Camber Specified Range: -0.8 to 0.2 degrees
Front Toe Specified Range: -0.03 to 0.18 degrees
Front Cross Camber: Before -0.2 degrees/After -0.1 degrees
Front Cross Camber Specified Range: -0.5 degrees to 0.5 degrees
Front Total Toe: Before 0.32 degrees/After 0.21 degrees
Total Toe Specified Range: -0.05 to 0.35 degrees
Rear Left:
Camber: Before -1.1 degrees/After -1.6 degrees
Toe: Before 0.56 degrees/After 0.14 degrees
Rear Right:
Camber: Before -1.7 degrees/After -1.4 degrees
Toe: Before 0.36 degrees/After 0.13 degrees
Rear Camber Specified Range: -1.3 degrees to -0.3 degrees
Rear Toe Specified Range: -0.03 degrees to 0.17 degrees
Rear Cross Camber: Before 0.7 degrees/After -0.3 degrees
Rear Cross Camber Specified Range: -0.5 degrees to 0.5 degrees
Rear Total Toe: Before 0.92 degrees/After 0.28 degrees
Rear Total Toe Specified Range: -0.07 degrees to 0.33 degrees
Thrust Angle: Before 0.1 degrees/After 0.0 degrees
Old 06-24-11, 09:51 AM
AKS14
AKS14's Avatar
Your running zero degrees camber in the front?
Old 06-24-11, 01:22 PM
slowdiver
slowdiver's Avatar
actually, if you read the numbers above, I'm running negative degree camber.
Old 06-24-11, 08:07 PM
eyecon7
eyecon7's Avatar
I feel like my car rides like crap after I installed these UCA's but the adjustabilty is great, but i feel like they affected my ride alot
Old 06-25-11, 10:12 AM
slowdiver
slowdiver's Avatar
Did your kit come with new caster arms or was it just a "camber" kit?
Old 06-25-11, 02:04 PM
GSteg
GSteg's Avatar
The SPC front kit is an UCA-only. It just happens that you can control camber and caster angle with it.
Old 06-26-11, 03:34 AM
jlsandov32
jlsandov32's Avatar
Where did you buy this kit and have it installed ?
Old 06-26-11, 06:26 AM
slowdiver
slowdiver's Avatar
Bought the kit directly through CL Vendor THMotorsports:
https://www.clublexus.com/forums/clu...our-tires.html
Install performed by Sonny @ Dynamic Auto in Midway City, CA.
http://www.yelp.com/biz/dynamic-auto...es-midway-city
Old 06-26-11, 09:45 AM
eyecon7
eyecon7's Avatar
I installed Diazen Caster arm bushings, but my car is slammed, so I think theres to much pressure on the UCAs
Old 07-05-11, 03:38 PM
scriber
scriber's Avatar
Where else other then TM can I purchase caster arm bushings?
Old 07-05-11, 08:26 PM
lexusben
lexusben's Avatar
Carson Lexus and Sewell Lexus sell the Bushings.
Old 07-06-11, 09:11 AM
scriber
scriber's Avatar
the only bushing kit I saw on Sewell was a single kit for the front steering rack. Nothing about bushings for the caster arms. I will call
Old 07-16-11, 08:26 PM
starfyrels
Account under Legal Action - Banned
starfyrels's Avatar
^ you need to buy the whole arm, theyy dont sell bushings.
tmengineering does, you can also try to get daizen directly.
Old 07-16-11, 09:41 PM
sakataj
sakataj's Avatar
SEWELL DOES sell a castor arm bushing actually...
http://lexus.sewellparts.com/accesso...2001/4685.html
but these WILL NOT work on the 1998-1999 models as they used the older castor arms which are a different sized arm than the others (i thought the 2000 models used the old ones too but according to sewells site these fit the 2000 so i dunno)
i thought u said u ordered already from TM scriber? U will EVENTUALLY get them from them,just have some patience. BTW you will NEVER get them daizen directly, todd @ tm is the ONLY authorized dealer anymore. a few dealerships,including sewell used to carry them but they werent dealers as they STILL got their supply from TM engineering. part of the reason they stopped carrying them at the dealerships is the problems getting them from tm and only todd and a few select OG's know the real story behind all this. if its really a problem getting them from todd or if todd is having problems getting them from daizen directly who is in japan....BTW last i heard daizen is under new management as the owner or founder died. i made a few notions a year or so ago to a few people about what it would take to become a dealer and get the supply of this brand moving again but i didnt really get anywhere with it.
if u wanna do some research on todd on here his SN is/was doublewhoosh or try here https://www.clublexus.com/forums/mem...osh.html#stats
his last post was in 2007 though guys so he isnt here anymore. i talked to him via email when i had a few orders in, he was pleasant for the most part than he stopped answering and finally im sure i annoyed him and he made me wait almost 60 days for my control arm bushing kit but my steering rack bushing kit i got really quick.
Old 07-19-11, 07:49 AM
starfyrels
starfyrels's Avatar
those bushings are news to me. is this new?
Those look like the same bushings that daizen sells.
Quick Reply: SPC Caster Arm/Camber Front & Rear kit is on (data adjustments included)
