LS Brakes
#76
^, I use the same method for general life. It doesn't show if one corner is wearing faster than the other or if there is a hydraulic leak but I have my wheels enough to get a visual inspection. One reason why I tell people not to fill to the master if the system is free from leaks. Once pads are replaced and the pistons are pushed back into their bores the master will fill up with the fluid from the calipers.
#77
Whoa, I never knew that you can actually base it from there... Y'know, back in Philippines all the cars that I've ever had, I've never had to replace the brake pads on any of them in the 12 years that I've driven there, and we usually change to a new car every 5-6 years, we can keep them longer but usually 5-6 years is when all the suspension problems comes out just because of our road conditions, and not only that, the most usual speed back there is just like 40km/h, which is like 25mi/h, and everywhere you go is stop and go traffic...LOL
#78
#79
Are they a direct bolt on or is there something else needed like the LS400 fronts where you need to use the LS bolts? I have a buddy who is setting up his Supra for drag racing and he is going with smaller brakes in the rear to use a 15" drag wheel. He said hed sell em to me. What do they go for? He has new pads and cross drilled/slotted rotors, what would you guys pay for em?
#87
Ok.... so I'm trying to keep my car as low key as I can....
Anyone ever swap the dust shields with either a tt or ls400? according to toyo diy's pics it looks like I should use the mkiv tt dust sheilds. For 36 bucks I might as well shoot in the dark if I don't get feedback...
#89
I wouldn't look at dust shields as part of being low key as most will not see them behind the brake rotor and caliper.
#90
The bearings should be about 40 bucks from toyota, not that 117k is a lot on them but I might just replace them. I took a look @ my brothers mkIII yesterday (he has a SC suspension under it)
