LS Brakes
#61
#62
You are correct, I checked another site and did the conversion. They're around 11" for SC3
Bottom line, the SC3 has smaller rear discs than the SC4. You don't have to be a twatwaffle about it
#63
#65
Hey guys! I've recently upgraded my brake lines to SS Goodridge brake lines and also painted my stock rotors and calipers which turned out really great looking! I'm hating my stopping power at the moment because the more I fix my cars problems it goes faster and now I notice that the stock brakes ain't really cutting it so I'm planning to change to the LS BBK as soon as all the fixing is done. I have all the parts already, just slowly finding time to get everything fixed. But, my question is, what BBK can I use for the rear except for the Supra TT or that is pretty much it? I'd really hate the look of my SC when the front brakes are big as hell and the rear is not proportion.
#68
So, I went to a few pick a parts over the last weeks and noticed that all the '95 LS400 that I saw only had 2 POT calipers. I was so excited when I found the LS400 at the pick a part. Where they just miss labeled as '95's or do only certain trim levels of the LS400 have the 4 POT calipers?
#70
Just got my LS calipers in today and took off the pads so I can prep hem for paint. I noticed a sensor with some wires or something on one side of the caliper. Is that needed on the SC or can I just ditch it? Pics will be coming soon.
#71
#75
Unless you keep filling up your reservoir when you see your fluid low, your fluid getting lower is a direct reflection on your pad wear. I've done it for years I see my fluid just below the half mark and for me that's when I check and or change my front and rear pads usually just the front (since 80% of the braking is done up front) pushing the fluid back into the reservoir syringe/turkey baster (at least that's what I call it) to suck out the now full again reservoir add fresh fluid and go on with my day. At some point you will have to do a fluid flush but I don't do one every time I change my pads I do use my air vac-bleeder when its time for that though its really a sweet tool. Just my 2penny's worth.
Please keep in mind this is just a friendly little discussion so don't get all upset over any of it.
