Tucking without tire wear?
Old 01-11-15, 12:25 PM
Nixcision
Nixcision's Avatar
Default Tucking without tire wear?
Hey guys,
I have already ordered a set of SPC ball joints and figs mega arms for my awd is250 for camber adjustment.
My original plan was to use these to correct camber to avoid tire wear when lowering my car 2.5"
(I already know about the awd lowering problems so don't worry)
BUT, I have seen so many pics here on CL of some sweet setups with owners tucking their wheels under the fender with camber....
I don't want too much camber, just enough to tuck my wheels under the fender the smallest amount...
Aren't you guys who have done this worried about tire wear?
Or does it not happen as fast as I think it does??
Thanks!
Old 01-11-15, 12:53 PM
senxation
senxation's Avatar
Camber doesn't normally kill the tires. Its the toe that does.
Old 01-11-15, 03:02 PM
Nixcision
Nixcision's Avatar
yeah Ive heard!
Old 01-12-15, 06:40 AM
heyarms
heyarms's Avatar
Thanks!
I dont think anyone loses sleep over their tire wear. lol get your toe in spec and theyll last longer than you think. If we were worried about tire wear, i dont think any of us would be running aggressive wheels
Old 01-12-15, 08:29 AM
Nixcision
Nixcision's Avatar
Makes sense... I'm considering in looking at the Figs bushings up front to stabilize toe a bit... a bit pricey tho... still saving up!
Old 01-12-15, 06:26 PM
Gville350
Gville350's Avatar
What amount of mileage are you expecting to get out of a set of tires? What is the treadwear rating of said tires?
Old 01-12-15, 08:53 PM
Nixcision
Nixcision's Avatar
running hankook ventus s1 noble2 225/40/18 on 18x8.5 wheels +35 all around (AWD)
rated 500 AA A....
looking to maximize tire life!
Old 01-14-15, 01:26 PM
Gville350
Gville350's Avatar
What is your budget on tire maximizing components? I'd start with rear camber arms and a good alignment. From there you can go with the adjustable UCAs, and of course the different various bushings. But seeing your comment on the "still saving up"...perhaps the bare necessities for now will get you by with only minimal tire wear losses.
Old 01-14-15, 11:07 PM
Nixcision
Nixcision's Avatar
My spc ball joints and figs mega arms were delivered this week... im just wondering:
A. If I even need them for tire life help - let the natural camber tuck the wheel a slight bit after lowering 2.25" --- Meaning I sell these
OR
B. If I can use these to both tuck the wheel and save my tires--- i.e. a middle ground between no neg. camber and #stancenation
Old 01-15-15, 12:20 PM
Gville350
Gville350's Avatar
Drop the car to your desired ride height first and install wheels (if you haven't already); then work from there.
Old 01-15-15, 12:41 PM
Nixcision
Nixcision's Avatar
The reason I was asking is because I purchased my camber kits first (i got a good deal on both), however, now Im tight on my budget to actually purchase the Coilovers to lower my car in the first place!
Basically I have camber kits, but no coils...
Curious if I should still wait and save up more OR sell my camber kits so I have enough to buy coils and risk tire wear (if there really is a risk in the first place)
Old 01-24-15, 01:07 PM
ISgetweird
ISgetweird's Avatar
Right now I have a 3" drop natural tuck and it's a pretty good look plus no tire rub (no fender mods, removed liners, etc.). The only issue I have is the front tires getting worn more than the rear. I also want to add a little bit of negative camber though.
Polo708
Suspension
10-11-17 08:03 PM
ClubLUser
08-28-17 08:09 PM
ray123
VIP Style
08-05-11 12:33 PM
hatteroo
01-17-11 09:44 AM
98GS400GUY
Suspension and Brakes
03-24-10 10:05 PM
Quick Reply: Tucking without tire wear?
