My GS on 370z wheels,LS400 Brakes, Teins & SAGE RCA
#61
#70
Sooo...I have STOCK suspension but (also) installed the LS4 front calipers/rotors (and LOVE them!!!- especially with the insane EBC Redstuff pads)-- But anyway, I installed (30mm) SAGE RCA's up front... and Exact Motorsports brand RCA's in the rear, which are only 20mm.
I wanted the car to have a similar wheelwell gap in the front and rear- and since our cars have a higher gap in the front, stock...I figured- until I buy some new coilovers it would APPEAR to be sitting nice and flat (although the front would be 10mm lower)
Problem is, the stupid (Exact) 20mm RCA's add 1 degree of positive camber at the LEAST (and up to 3 degrees- at the most) and my car had POSITIVE camber in the back ! Is the camber in the back adjustable- because I got it alligned again- and now it has -5 degrees neg camber (which is perfect....... THING IS, I think the only reason is because I put about 150 lbs of WEIGHTS in the spare tire well. So rigged at the moment... KILLIN ME!
2jzgttegs- I know you have your GS lowered- but it seems to sit SOOOOO perfectly. Daaahhhhaaamit, I should've bought the SAGE RCA's for the rear!
Anyway- YOUR 'Beige Metallic' GS looks great, at least ! ha... Here's a pic of how mine is currently sitting with the massive 150 lbs of extra weight that I had to add to trunk well to get it sit where it's sitting currently. ttsshhh... I really need to order some coilovers asap. lol
(the 2nd pic is from last year- before I added the 25mm adapters on the rear wheels. Now, other than the suspension being horrible- at least both sets of my factory wheels are FLUSH.)
