DIY - Replace Brake Master Cylinder Booster
10-24-10, 05:35 PM
I have a 98 GS400 and wondering if there's a DIY to replace it?
10-24-10, 07:12 PM
its really easy theres only 4 bolts and the the lines on the unit and 3 plugs
10-26-10, 04:00 AM
Quote:
Originally Posted by
toy4life86
As for bleeding, is there any special type of bleeding measures or is it the standard bleeding from the brakes?
10-26-10, 08:33 AM
in general, bleed the side with the longest distance first...but it's harder to tell with more modern cars.
10-26-10, 10:18 AM
That's a pricey part. Are you sure it's the master?
Symptoms?
10-26-10, 12:10 PM
i was having problems bleeding until i bled from the master unit, so id recommend bleeding the master unit
10-26-10, 04:45 PM
werewolf
Symptoms?
Just replaced it and bled from the brakes... So far no lights and brake feel is MUCH better. I found a used one from TX.
10-26-10, 04:48 PM
Bench bleed the master cylinder first... That means bleeding it before installing on the car. Then bleed from farthest line (Rear passenger, rear driver, front passenger, front driver). Done!
10-26-10, 08:55 PM
this is something i should do when i replace my pads and rotors.
10-26-10, 11:29 PM
Can we convert to a vacuum booster and external ABS unit?
10-27-10, 01:07 AM
I think that'll be an expensive solution. Might as well get a 2001+ BMC.
10-27-10, 10:21 AM
YviE
What's different about a 2001+ BMC?
10-27-10, 12:14 PM
YviE
Maybe an LS400/430 set up? When the BMC is $1,300ish, you think outside the box. Obviously safty would be #1. I'm not saying "Let's do ghetto conversions based on theory. Hopefully it works out better than communism." It was just a thought.
10-27-10, 12:31 PM
The 2001+ BMC doesn't have the design flaws of the 98-00 BMC. There are threads about this.
Mick2
Suspension and Brakes
27
06-18-19 11:06 AM
ls400beave
13
06-20-12 07:59 AM
toy4life86
14
09-03-10 05:14 PM
bb7110
09-03-09 12:41 PM
2001 ,
ae86 ,
bleeding ,
booster ,
brake ,
cylinder ,
diy ,
gs300 ,
gs400 ,
installation ,
is300 ,
lexus ,
master ,
supra ,
toyota
