Replacing stock brake pads and rotors
Hello cl fam
I've come here to get some input regarding stock brakepads and rotors. For the last 2 wks I've been hearing the infamous 'squeaky' brake noise when I come to a stop. The noise is more audible when coming to a stop slowly from moderate speeds. The noise is the typical 'screeching' brake noise that you hear. The IS has 27k miles on it. When I took it to the stealership they told me both the rotors and brake pads need to be replaced costing around $500.
Does this make sense? What mileage do our IS's generally have their brake pads and rotors replaced? I have a gs 350 with 70k on it and have yet to replace the brake pads or rotors. I'm surprised that is's need there stock brake pads and rotors changed at such a low mileage.
Lastly, if I do have to get them replaced, why isn't this a warranty issue?
Thanks for your input.
Well first off your dealership is trying to scam you. If they are charging $500 they are not replacing the rotors, just replacing the pads and resurfacing the rotors. Your brake pads may be shot, it depends on how much you use the brake. I replaced my front pads for the first time at around 45k but i didn't do so because of the pads i did so because of the uneven deposits on the rotors and I wanted to get them resurfaced. I would highly recommend you do them yourself as it's such an easy job but if you're not handy or mechanically inclined then i would go to a local shop to have it done. It will cost you less than half that to get the job done. Lexus dealerships charge and outrageous amount for simple wear and tear replacement. I will tell you this though, do not let anyone convince you that you need to replace the rotors. The rotors on the IS350 are very heavy duty and unless you are tracking the car heavily they will not warp. When replacing pads you should always have the rotors resurfaced and it will make your car feel and stop like new. The IS350 rotors can be resurfaced about 3-4 times before they need to be replaced.
same problem im at 30k miles almost and i have gone through 2 sets of front pads and the rotors have been resurfaced before already. first issue was around 20k miles, pads still had 50% but the pads were warped and then rotors needed to be resurfaced. this is the second time, the pads have 60%+ but the rotors are lipped. so now i need new rotors and pads they said. im thinking that, these pads are messin with the oem rotors, like they are too hard for the rotors or something, im thinking about sticking to oem rotors and swapping out the pads to aftermarket, maybe something softer? different material.
First, rotors don't really warp if correctly installed... and certainly not in any sort of normal use...
Sounds like maybe you're not bedding the brakes correctly in the first place and getting uneven material transfer though?
http://www.stoptech.com/tech_info/wp...rakedisk.shtml
Seriously, read the link I posted.
The guy who wrote it saw a lot more brakes than you, under a lot worse conditions than you, and supports the idea of "warped" rotors being a myth largely repeated by folks who don't understand material transfer in rotors.
If you don't believe HIM try this:
http://www.brakeandfrontend.com/Arti...brake_job.aspx
Editor of Brake and Front End Magazine, who also tells you rotors don't generally warp.
What was wrong with the rotors that they needed resurfacing?
Xzria
RC F (2015-present)
01-03-19 10:56 PM
