Front end clunk, ball joints, end links, and suspension please advise!
Old 09-28-10, 01:03 PM
fastturbo
fastturbo's Avatar
Default Front end clunk, ball joints, end links, and suspension please advise!
Hey, trying to combine a few things into one thread so bare with me. I mostly keep my nose over at supraforums but I figure I'd give this place a shot.
Quick rundown of the vehicle:
98 GS300, 125k miles, new brakes/new wheels & tires, car is a one owner and in fantastic shape all around.
Issue #1 - Clunk coming from front left it seems when turning slowly out of a driveway/road or going over bumps fast. What would this typically be related to? ball joint going? sway bar end links?
Issue #2 - light to light moderate vibration from the steering wheel at 60-65mph, wheels and tires are brand new, alignment and balance completed 400 miles ago. Related to above issue?
The third thing is not really an issue. I'm looking to put new springs/shocks on the vehicle. Looking for 1.5-2" drop all around, whats my best bang for the buck?
Thanks in advance for the responses.
-Matt C
Old 09-28-10, 07:56 PM
fastturbo
fastturbo's Avatar
holy crap after searching all the "steering vibration" threads on here my head is spinning. Seems like alot of guys just did the shotgun blast repair approach, IE. Replace everything in the suspension and hope that fixes it". I don't really have an interest in replacing everything and hoping. Hopefully someone thats been through this has some insight.
Matt
Old 09-28-10, 08:54 PM
pizdets17
pizdets17's Avatar
you have a better chance of having a period. No one thing has fixed this, I am in the same boat. Something that worked for some did not for others.
Old 09-28-10, 09:17 PM
ZippyGuy
ZippyGuy's Avatar
This has been covered TONS of times on the site, I'll give this another overview of if/then scenarios:
1. check wheel balance using Hunter Road Force technology (http://www.gsp9700.com/)
2. check alignment using Hunter alignment technology (http://www.hunter.com/alignment/wina...mium/index.cfm)
3. check bolts and tension on sway bar and links
4. check steering column bushing (replace with Daizen)
5. replace lower ball joints
6. replace upper control arm (I would suggest upgrading to the Daizen bushings at this time)
7. replace lower control arm bushing with Daizen bushing
I would do this after checking to make sure everything including the lugs and suspension components are properly torqued to spec.
Old 09-29-10, 08:39 AM
pizdets17
pizdets17's Avatar
Where would I find a spec sheet?
Old 09-29-10, 12:17 PM
Blk04GS430
Blk04GS430's Avatar
Can someone pls provide me with the information on what are the proper specs to torque the lugs and suspension components. thanks
Old 09-29-10, 04:45 PM
ZippyGuy
ZippyGuy's Avatar
Search function:
2GS 300/400/430 HALL of FAME Links thread (look in here first O.Gs and newbies)
https://www.clublexus.com/forums/gs-...d-newbies.html
then,
LINKS TO MOST DIY (Do it yourself)
https://www.clublexus.com/forums/gs-s...ou-search.html
then,
GS430/300 Service Manual:
http://bahamutcars.free.fr/workshop/...nts/index.html
you = NOOB
Old 09-29-10, 06:05 PM
pizdets17
pizdets17's Avatar
service manual comes up empty for me, to "tree root" lol, you ever check these links "noob"?
Search function:
then,
https://www.clublexus.com/forums/sus...ou-search.html
then,
you = NOOB
Old 09-29-10, 06:14 PM
fastturbo
fastturbo's Avatar
Thanks for the insight, we have one of those hunter 9700 machines at our Honda store. Drop it off the in morning and report back.
Checked ball joints, they are in perfect shape.
Old 09-29-10, 07:57 PM
ZippyGuy
ZippyGuy's Avatar
Really, not trying to insult you, just trying to have you use the search function instead of posting threads that are redundant. I'm far from a noob and this subject is covered multiple times per year with the same results and the same direction. I use the manual like a "Lexus Bible" whenever I work on my car and yes, I do 75% of my own work.
Directions:
GS430/300 PDF Manual
Applicable models : UZS161 series
JZS160 series
Click the desired item from the pull down menu on the left.
Note : Please wait until the pull down menu is displayed.
Viewing the contents requires Microsoft Internet Explorer 5.0SP2 and Adobe Acrobat Reader 5.0 or greater.
Repair Manual/Suspension and Axle/Front Lower Suspension Arm/Components
Good luck!
Old 09-29-10, 08:08 PM
pizdets17
pizdets17's Avatar
i dont have IE on my comp at home, will dl at work, thats probably why it doesn't work
Old 09-30-10, 01:17 AM
Blk04GS430
Blk04GS430's Avatar
Question
Directions:
JZS160 series
Good luck!
Hey bro it worked for me! Thanks
Is there any way to save the whole manual instead of saving each page 1 by 1?
Old 09-30-10, 09:24 AM
ThomasGS4
ThomasGS4's Avatar
Best bang for your buck drop are Tanabe DF210 springs.
Old 10-08-10, 03:14 PM
fastturbo
fastturbo's Avatar
Hub centric rings fixed my shake completely. So far so good.
Old 10-08-10, 04:57 PM
Blk04GS430
Blk04GS430's Avatar
Hows the ride on the Tanabe DF210 springs? What shocks/struts are you using?
Quick Reply: Front end clunk, ball joints, end links, and suspension please advise!
