BAD Rear Suspension SQUEAK!
Old 03-04-11, 11:55 AM
Mr Soarer
Mr Soarer's Avatar
I jacked up the car and found the problem... its the lower ball joint on the spindle. It has some play in it. Since im selling the car I didnt want to replace it, took out the adjustment bolt, remove the lower arm so i can spray white lithum grease in the boots on both sides. Put it back together all gone.
Old 03-04-11, 12:40 PM
GS4_Fiend
GS4_Fiend's Avatar
^ lower ball joint from the rears???
Old 03-04-11, 11:26 PM
Mr Soarer
Mr Soarer's Avatar
It may not be called a ball joint but its where there lower control arm connects to on the spindle
Old 04-01-11, 02:50 PM
cgonzalez
cgonzalez's Avatar
yup thats exactly what it was on my gs400 it sucks cuz i sprayed white lithum grease on it and it went away but now its back >:O
Old 04-01-11, 08:40 PM
GS4_Fiend
GS4_Fiend's Avatar
Nice. That's probably the culprit for me also. Thanks
Old 05-02-11, 08:53 AM
Blanco
Blanco's Avatar
So can we replace just the joint/bushing or does the whole spindle need to be replaced? I've got this on my left rear, and it squeaks every time I get out of the car. Not as bad now in the warmer weather, but I've got to fix it.
It's driving me crazy!!
Old 05-02-11, 10:23 AM
GS4_Fiend
GS4_Fiend's Avatar
Damn. Still haven't had time to check it out.
Old 05-04-11, 07:22 AM
starfyrels
Account under Legal Action - Banned
starfyrels's Avatar
http://stores.autowearhouse.biz/-str...category=Lexus
Figs will chime in that this isn't the right thing but the other spherical joints from rhdjapan.com (search aristo) for the rear carrier axles are like $180. There are a few guys running these and some other ones from the UK with no issues.
Old 05-04-11, 08:01 AM
Blanco
Blanco's Avatar
So let me get this straight. The bushing in the link you posted replaces the circled bushing in the pic above?
How does going from rubber to polyurethane affect the ride?
Old 05-05-11, 12:31 PM
MatthewG
MatthewG's Avatar
I too have the squeak.
Does anyone know if this bushing can be replaced with the spindle on the vehicle or does the spindle need to be removed to get it on a press?
Old 05-14-11, 10:49 AM
lexybaby77
lexybaby77's Avatar
Unfortunately it cannot be replaced. It needs to be pressed.
Old 05-14-11, 01:32 PM
marshun
marshun's Avatar
cant be replaced but can be pressed? so you CAN replace it.
http://www.l-tunedparts.com/product/?id=3322
dont really need a press either. just some time
Old 07-20-11, 09:38 AM
whytry
whytry's Avatar
Who has done this without a press? Can you give me some ideas on how it was done? THX
Old 08-31-11, 08:39 PM
whytry
whytry's Avatar
Anybody done it without a press?
Old 09-02-11, 07:29 PM
whytry
whytry's Avatar
I think I have the right part number I got ADUS 690 Rear Axle Carrier Bushing - OE # 42304-30070....
This is what I got
Quick Reply: BAD Rear Suspension SQUEAK!
