SPC upper control arms = waste of money
Old 06-25-10, 03:02 PM
  #31
sam430
sam430's Avatar
I'm looking to replace my UCA, can someone link me to the resource to purchase them? I'm looking for all option, including SPC, Ikea, etc..
Please PM me. Thanks.
Old 06-25-10, 10:14 PM
  #32
UpstateLex
UpstateLex's Avatar
so the sum of this thread basically indicates running BC coilovers there is no perfect suspension to run with this set ?
Old 06-25-10, 10:40 PM
  #33
motolex722
motolex722's Avatar
What do you mean by this? Basically this thread sums up a few things about spc upper control arms & bc racing coilovers.
SPC UCA
-Don't change ride height.
- Because they are thicker & taller, tucking tire = hitting in a few places
- Limits of ball joint are reached when running at a very low ride height (tucking tire).
- Don't work well with RCA's because of hitting issues but depending on how much tire you plan on tucking, you will always run into this problem no matter what UCA you run.
BC Racing Coils
- Unable to tuck front tires w/o use of RCA's
- Rears are able to tuck tires w/o use of RCA's
Old 06-28-10, 10:25 AM
  #34
SpecProd
SpecProd's Avatar
Originally Posted by GS300ToM
imma just try it for the hell of it and see what happen... my goal is to run -2 camber up front since it sitting at -3...
EXACT RCA + SPC UCA + Megan coils... next month tho
Please keep me / this thread updated, looking foward to seeing this setup.
~Travis
Old 06-02-11, 10:00 AM
  #35
Cuban GS
Cuban GS's Avatar
any updates? i would like to purchase a set for my JZS147!
Old 06-09-11, 02:33 PM
  #36
eyecon7
eyecon7's Avatar
Bump I dont have RCA but when I installed these and new caster arm bushings it raise my car, Also My camber it about .02 but there is a steep angle I wanna go lower, and can I with RCA's?
Here are some pics with my coils maxxed out and the car sitting on the ground.
Old 06-09-11, 08:10 PM
  #37
SlowGS4
SlowGS4's Avatar
^^^ can you add pictures of how dumped your car is from the side?
Old 06-09-11, 08:55 PM
  #38
kit cat
kit cat's Avatar
wow, I was on HKS Hipermax LS with RCA but holy crap, never realized how angled the upper control arm must have been...
I guess you can go lower with roll center adjusters, but most likely your upper arm will start hitting the top of the wheel well even more.
also, you might want to be careful with that cotter pin...looks like its hitting your tires (last pic)
Old 06-09-11, 11:14 PM
  #39
vwynn
vwynn's Avatar
i dont think the pin would scrape the tire since it moves with the whole suspension/whee/tire.
interesting how steep of the angle is on a lowered car lol. now im thinking.. what if there was a slight angle on the UCA where the balljoint is.. so that the mounting area + the spindle thing are parallel to eachother. would that be beneficial? i might give a tiny bit extra clearance. but obviously dont just go out n hammer the UCA lol... hopefully FIGs has something in mind hint hint
Old 06-11-11, 08:47 PM
  #40
eyecon7
eyecon7's Avatar
Exactly what i was Thinking!!!!! yes Figs Hint hinT
Old 06-14-11, 11:15 AM
  #41
Pnuge88
Pnuge88's Avatar
damn after reading all this i'm glad i didnt buy the spc UCA camber kit yet..
Old 07-20-11, 04:30 PM
  #42
FinLIFE
FinLIFE's Avatar
I am looking into buying something to correct my camber and spc was one of my choices without beeing too expensive. I wonder if figs has anything in store for uca's..
What is everyones experience with spc rear camber correction?
Old 07-21-11, 05:52 AM
  #43
cjames235
cjames235's Avatar
i have both the front and rear SPC and they both work well...... bottom line here is if you are dumped it will put any UCA at an extreme angle..... this is not a specific SPC problem (although the extra banging IS a SPC problem)
what our cars need is an option for a shorter knuckle OR someone could go and convert the front suspension into a mcphearson setup and eliminate the UCA all together
Old 07-22-11, 01:50 PM
  #44
FinLIFE
FinLIFE's Avatar
For our lowered cars we need control arms that angle down to be parallel to the top of the spindle. That way the ball joint would be straight and under less stress....if figs ever makes a set im buying.
Old 07-22-11, 02:45 PM
  #45
AKS14
AKS14's Avatar
Originally Posted by motolex722
BC Racing Coils
My fronts could easily tuck tires and im on BC "Extreme Low Spec" coils.
Heres how they sit out of the box, no adjustments made, springs havent even settled.
19x9 with a 225/40
And heres with a 19x9 with a 225/35
Quick Reply: SPC upper control arms = waste of money
