Brake master cylinder help
Cliffs:
installed Willwood BBK on fronts.
noticed leaks on the floor prior to bleeding near the left frame rail up front.
tried bleeding the brakes but cant get a stiff pedal, the pedal falls to the floor.
Could my master cylinder have given out and its a coinsidence that it happened now rather than a BKK problem.
im currently checking for leaks at the master cylinder. what im curious about is the location of the leak under the car. its not directly under the BMC but about 8 to 10 inches back on the frame rail. Is there a line that runs thru or near there? the rear lines run on the opposite side correct?
bloodyKnuc
GS - 1st Gen (1993-1997)
11-18-15 12:00 PM
