Vibration and noise
Old 05-19-10, 04:58 AM
edipolo613
edipolo613's Avatar
Default Vibration and noise
I have installed Eibach lowering springs and H&R 15mm front and 25mm rear wheel spacers, I keep balancing and aligning my wheels and tyres but I still get vibrations specially my rear left which also makes noise like the tyres are offroad tyres (I'm running goodyears gsd3 all around 235 45 17s with original Aristo wheels) my lex is a 1999 gs300 with 230,000+ kms.
Old 05-19-10, 05:23 AM
IXI187IXI
IXI187IXI's Avatar
you probably want this in the 2nd gen suspension forum not the 3rd gen but none the less, are the spacers hubcentric? do the spacers have studs on them? if not, did you order longer studs or lugs?
Old 05-19-10, 10:38 AM
GS4_Fiend
GS4_Fiend's Avatar
I had the same problem. Got a road force balance and retorque the spacers and wheels and problem solved.
Old 06-08-10, 03:18 PM
designo
designo's Avatar
Same problem here, you might want to double check the hub bore size of the spacers and their hub rings if any. Also, if all is okay, re-torque the spacers and wheels again.
RTIS250
CT 200h Model (2011-2017)
33
12-07-15 10:00 PM
anhvn05
04-05-13 02:27 PM
CHAPIN33
01-27-08 09:31 AM
lexodude
Wheels, Tires & Brakes Forum
03-14-07 06:06 PM
Quick Reply: Vibration and noise
