NEWBIE! need help with lowering car
never dropped a car before and never looked too muich into it.
did some quick searches but with all the parts there are now idk what would be too much and whats good enough, give me some help please?
want to lower my gs for better look but want to keep as much as oem performance as possible (dont want to deal with problems later on).
in general, what parts would i really need to get it done right?
help would be appreciated! THANKS!
and im just trying to get a general idea.. if it takes too many parts and too much money, then i'l back off the drop.
im looking to give my gs a better look, but dont want to add too many mods or change it too much. as oem as possible.
Super Moderator
You really have to determine how much you want to spend, then how low you want to go, and then how much firmer you want or don't want the suspension to be from stock. Then you can make your game plan and get the right products that fit your needs.
When you say this do you mean you want to keep as much of the stock ride comfort and feel as possible? You want it to ride like OEM stock but just lower? How much lower do you want to go? Most springs drop between 1-1.5" average. Some drop a little more, but generally the lower the go the stiffer they are. Coilovers give you a lot of options, but are more expensive and sounds like more than what you are looking for if you don't plan on lowering much past the 1-1.5". You can use RCA (Roll Center Adapters) that will lower you about 1-1.5" (Depending on brand) and retain the OEM stock ride comfort. Basically, if you use RCA's on stock springs/shocks, you will have the look as if you lowered with springs, but with 100% stock ride comfort and feel.
yeah im looking for as much stock ride feel as possible but still get a drop. im not sure how low i want to get it, i guess id have to look around and see what drop looks good to me. as far as money, i have never lowered a car and barely looked into prices, so i pretty much have no idea what price ranges im looking at. il be flexible to that though, if theres a look i really want and it takes expensive parts to get it, then i guess thats what il go for, otherwise il work with the prices i see that itl cost me for the drop. the RCAs sound like a good idea, but i guess il have to look more into both. which would you suggest?
Super Moderator
very good description and advice. thanks man, this is the help im looking for.
my bad guys, you guys were helping me and i didnt reply to the thread. sorry, i wasnt subcribed, thought i was..
well i dont know how low i want, i guess id have to measure how much lower i want than from where im at. a good example of how id like to be at would be like this:
(last pic. posted up by nokcy21)
https://www.clublexus.com/forums/gs-...to-drop-3.html
robertoyou, i was in ur shoes few years ago, then i ended up bought tein spring + kyb shock...then months later, after seeing a bunch of sick GS in this forum, i've decided to get coilover. if I have to do it all over again, i'd save more money and go straight to coilover.
You can adjust coilover easily, drop it on weekend or for lexus meet, then put it back as normal on weekdays
NEW spring + shock = ~ $300 - $400, depends on brand
USED coilover $650 ~ $900 depends on brand.
as you as, the difference is not that much.
my car is pretty much daily driver as well
save ur money more and get coilover, you won't regret it !!
sk8r78664
Lighting
02-29-08 07:21 PM
