COILOVER QUESTIONS and need quick answer
Old 04-19-10, 09:40 AM
jameshtx
jameshtx's Avatar
Default COILOVER QUESTIONS and need quick answer
wuddup.....i just got my tein ss coils installed and right now it seems to be ok and normal...here's my question...how would i know if any one of them goes out of get defected?
james
Old 04-19-10, 09:48 AM
Anthony
Anthony's Avatar
they can leak, you can start hearing akward noises, etc.. you would know
Old 04-19-10, 09:51 AM
jameshtx
jameshtx's Avatar
if it leaks, would you see it on your wheels? what color is the grease?
Old 04-19-10, 10:05 AM
duby1
duby1's Avatar
you will notice if there's a leak or... When you drive on it one side is bouncy than the other.
Old 04-19-10, 03:22 PM
5t341th
5t341th's Avatar
should be the same symptoms of a bad shock
Old 05-06-10, 12:59 PM
jameshtx
jameshtx's Avatar
damn now i hear a weird clicking sound in the left rear..sounds like a two loose washers hitting each other...what could that be??
Old 05-06-10, 01:05 PM
IXI187IXI
IXI187IXI's Avatar
you would know if they are blown. just because a strut does not leak does not mean its not blown. if their installed on the car, go to each corner of the car and push down on it and see if the car rebounds. if you press down and its firm and come back up right away then your struts are fine. if its pretty easy to push down and it takes a few seconds for the car to return back to its height, then the struts are blown.
Old 05-06-10, 01:47 PM
PHML
Master Thread Closer!!
PHML's Avatar
when driving...and hit a bump....and it goes "thump"...then its blown. That's the first thing i noticed on my old Tein CS v1. Then checking the tubes...I saw fluids leaking down the side of the tube...and onto the lower arm.
Old 05-07-10, 06:29 AM
IXI187IXI
IXI187IXI's Avatar
^^ not all the time. you can get the same noise from bad strut mounts also which a lot of people confuse with blown struts.
Old 05-07-10, 05:13 PM
GSJake
GSJake's Avatar
^^ How do you diagnose a bad strut mount? Pillow ball or rubber...
penone
Suspension and Brakes
10-07-15 05:24 PM
rudy88
Maintenance
06-17-14 07:19 PM
99lexus
05-28-07 03:10 PM
YoungChris
05-01-07 01:32 PM
Dramon
10-24-05 11:36 PM
Quick Reply: COILOVER QUESTIONS and need quick answer
