SAGE Front RCA (30mm)+LS400 Calipers+15mm H&R spacer+16" Stock Wheels = NO RUBBING!!!
Old 04-11-10, 02:38 AM
PHML
Master Thread Closer!!
PHML's Avatar
Default SAGE Front RCA (30mm)+LS400 Calipers+15mm H&R spacer+16" Stock Wheels = NO RUBBING!!!
I slapped on my stockers today to get a safety check.....but also to answer a few PMs from other members who wanted to know if SAGE front RCAs (30mm) will NOT rub the inner wheel barrels of the stock 16" wheels....the answer is NO rubbing....
I also have LS400 front calipers with LS400 size rotors....I used 15mm H&R spacers....as you can see....also NO rubbing issues... ....there's like a 4mm gap from the top of the LS400 caliper to the inner wheel barrel (my wheel balance weights is 2mm thick...so now I only got 2mm left ). Also, there's about 3mm from the wheel spokes to the face of the LS400 caliper.
LS400 Calipers and inner barrel with wheel weights...barely clears...
LS400 Calipers and 16" Stock OEM wheel spokes...also clears...
I hope this helps everyone....esp those who are running 16" stockers...that SAGE RCAs are possible.
And yes...I did drive on it...to a Chevron station for the safety check and some gas...again...no problems.
Pete
Old 04-11-10, 03:58 AM
CK6Speed
Super Moderator
CK6Speed's Avatar
Cool. I thought we no longer need RECON for larger rims anymore? You should have been able to pass with any size rims now I thought.
Old 04-11-10, 08:50 AM
sakataj
sakataj's Avatar
great info pete, thanks
Old 04-11-10, 10:00 AM
GSteg
GSteg's Avatar
The love the wheel to brake fitment ratio. Combined with the worn out tire, it looks mean
Old 04-11-10, 11:42 AM
rgarjr
rgarjr's Avatar
tight fit.
Old 04-11-10, 12:00 PM
ThomasGS4
ThomasGS4's Avatar
Nice. No pics of the car on stockers?
Old 04-11-10, 03:11 PM
Anthony
Anthony's Avatar
^ id like to see that too! wonder how low your vertex was lol
Old 04-11-10, 03:34 PM
PHML
PHML's Avatar
Yah...I heard the same thing...but didn't want to chance it at the chevron station.
Old 04-12-10, 01:20 AM
PHML
PHML's Avatar
Worn out tires....LOL....I gotta thank dear ole mom for that....her 2GS platinum stockers needed new tires....so I offered her to use mines....well, 25K miles later...I got them back like this......pretty much bald.
Old 04-12-10, 01:31 AM
PHML
PHML's Avatar
Pic on stockers...and height of my vertex front bumper.
Old 09-07-10, 11:00 AM
2gs300
2gs300's Avatar
did you have to change out your wheel studs with the spacers?
Old 09-19-10, 07:42 PM
PHML
PHML's Avatar
for my situation..yes..cuz my Work wheels didn't have the extra spacing for the bolt-on spacer studs...so I had to use spacers with new extended studs.
Old 09-19-10, 07:47 PM
greyhndfan
greyhndfan's Avatar
keep these tires, looks better..lol.
Old 09-19-10, 09:26 PM
Yang1815
Yang1815's Avatar
Holy crap talk about a tight fit.
Old 02-12-11, 07:50 AM
lexusscturbo
lexusscturbo's Avatar
Question, when you installed the LS400 BBK did you need to cut any of the dust shield off?
Quick Reply: SAGE Front RCA (30mm)+LS400 Calipers+15mm H&R spacer+16" Stock Wheels = NO RUBBING!!!
