DIY - Daizen Caster Arm Bushing Installation - lots of pics!
Old 05-21-13, 07:18 AM
  #196
Jere33my
Jere33my's Avatar
I couldn't get it to line up using the wrench.
Old 05-26-13, 07:50 PM
  #197
iamkhanz
iamkhanz's Avatar
Added list of full suspension part numbers, cost and where the part is made in many are in Japan which I was very happy to see, some in Taiwan, Korea and Thailand. THis is on post 191 on page 13. These are all from RockAUto and a couple parts like bushings Prothane and Sewell sourced elsewhere.
Old 07-11-13, 11:38 AM
  #198
Phillie
Phillie's Avatar
Very interesting thread. Quite a few choices to choose from. From what I've read Roca would be the way to go to be closest to OEM. FIGS would be the way to go if they were in production for a upgrade to OEM and Sewell for one under OEM.
I've always used OEM bushings with my Honda. I've also used Energy Suspension but preferred OEM. When it came to ball joints MOOG was my goto brand.
Old 07-11-13, 11:55 AM
  #199
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
Sewell is OEM
Old 07-13-13, 07:49 PM
  #200
Phillie
Phillie's Avatar
Thank you. After reading it over again Sewell is OEM.
Didn't see a part # for Roca. Is this it? RC-666092
Old 07-25-13, 08:00 AM
  #201
iamkhanz
iamkhanz's Avatar
Just wanted to provide an update, had a couple people PM me.. all the suspension updates have been made to the GS and comparing rides to Sewell bought OEM Lexus parts to RockAuto bought Raybestos they are equivalent in driving...
I kind of feel like the Raybestos feels a bit tighter.. but it could just be in my head. I did get a couple additional things done to the new GS then I did the older GS..
Also all my work was performed at Stereo EFX in Houston TX north-side.. good fair place to get things done. I bought all parts and had them put them in. My car is from the North so it did take them a week to get it scheduled in and completed ..but all done now, In the South..no one wants to work on cars from the North lol, but things like rust from salt and snow up north make it painful to remove parts. They painted my TTE lip/L tune grill/Sport Design Spoiler that I picked up from members on our board.
Old 07-25-13, 08:43 AM
  #202
tmf2004
tmf2004's Avatar
thanks for the update.. pics of the GS..
Old 08-11-13, 09:27 PM
  #203
Phillie
Phillie's Avatar
Today I finally got to installing my Roca caster bushings. I chose these because they are the closest to stock. At this point of time I also replaced my tie rods and lower ball joints.
After all the reading of how hard it would be to get the caster arm back in I decided to isolate anything that would give me any problems. It also helped that I did everything else at the same time. I found that if you have the lower ball joint, tie rod and strut disconnected its a breeze to thread the caster arm bolts. When I say breeze I mean I didn't have any problems whatsoever. So if you can do it this way you will not have any problems getting the arm back in.
I referred to this thread for the tie rod and lbj remover.
https://www.clublexus.com/forums/ls4...ll-joints.html
The only thing that gave me a problem was removing the old bushing. If there is ever a next time I'll be sure to cut out the rubber first before pressing out the bushing.
Old 09-07-13, 09:06 AM
  #204
iamkhanz
iamkhanz's Avatar
just checked the thread again thanks for the update how are the Rocas working? were the parts stand with country of origin? Just curious on where they are made.
Old 09-07-13, 11:53 AM
  #205
lyonkster
lyonkster's Avatar
A year and a half on Rocas, still like a new car
Old 09-30-13, 08:18 PM
  #206
Lexicious
Lexicious's Avatar
Shiii$* OK I bought a complete front end bushing kit from TM(daizen) the issue with the inner metal sleeve anyone put in their own to correct gap? Or modify dremel the upper or lower part of bushing to receive a solid mount? On the caster arm. Plus aren't the poly bushings better for handling and performance?
Old 10-07-13, 12:03 PM
  #207
FIGS
The Maker
FIGS's Avatar
Hi guys, finally have our design in as of today for 2001-2005 #2.
http://shopfigs.com/v1/index.php?rou...product_id=221 edited link
We also have an adjustable offset version which when combined with our #1 bushing will provide camber adjustment.
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old 10-08-13, 07:25 AM
  #208
sakataj
sakataj's Avatar
http://shopfigs.com/v1/LEXUS%20bushi...product_id=196
mike i think you meant to post this link?
Old 10-08-13, 08:31 AM
  #209
FIGS
The Maker
FIGS's Avatar
Thanks Brian, yesterday was a bit crazy.
__________________
Old 10-09-13, 04:08 AM
  #210
tmf2004
tmf2004's Avatar
Mike, from the pics you posted looks like the inner sleeve doesn't fit the bushing? Looks to small unless its just picture.. Is that actual item in the pic?
Quick Reply: DIY - Daizen Caster Arm Bushing Installation - lots of pics!
