List of wheels that fit TT and LS400 BBK
Old 08-31-14, 11:49 PM
  #76
t2d2
t2d2's Avatar
Originally Posted by 93aristogs
Anyone know if the GS430 chrome/2nd gen Aristo Chrome tt 17 inch wheels fit over supra tt brakes and or ls400 brakes. Dont flame me but i didnt see this wheels covered or confirmed.
I have the non-chrome version of those wheels and they won't come close to clearing the LS400 calipers. You'll need at least a 15mm spacer, and possibly 20-25mm, based on my rough measurements.
Old 09-22-14, 11:47 PM
  #77
Coldworld
Coldworld's Avatar
Thanks to all that replied this has helped me as well
Old 10-02-14, 06:49 PM
  #78
BRSpdStr
BRSpdStr's Avatar
19x8 Lowenhart LS1s?
Old 10-11-14, 06:43 PM
  #79
3L4jzz31
3L4jzz31's Avatar
So since this question seems to come up often with if a wheel will fit or not, in reference to measurements if somebody with tt calipers could do measurements on their car to confirm it would be much appreciated
TT rotor has a 30mm wide contact area w/ an additional 19.53mm "top hat" which the wheel sits on.
The TT caliper has a width 180.975mm. divide by 2, so half the caliper width is approx 90.5mm. Now assuming the caliper sits directly over the 30mm wide section of the rotor that means the caliper would overhang/protrude approx 56mm.
90.5mm - (15mm + 19.53mm) = 55.97mm
(Half of caliper width - (half of rotor contact patch width + top hat width) )
If this is correct that means you could measure a wheel from where it contacts the rotor (the backspacing) to approximately the region of the spoke where the caliper would contact. If this measurements is greater than 56mm or 2.205" by at least 4mm or more then the wheel SHOULD clear the spokes.
THIS STILL NEEDS TO BE VERIFIED BY SOMEBODY WITH TT CALIPERS THIS IS ONLY THEORETICAL CALCULATIONS BASED ON MEASUREMENTS FOUND ON AUTOPART STORE'S WEBSITE.
WILL EDIT TO CONFIRM OR DENY
Old 11-18-14, 06:09 PM
  #80
oldManTan
oldManTan's Avatar
anyone know if these 350z wheels in particular will fit on Supra TT brakes? they're 8" wide i think
Old 11-20-14, 08:39 AM
  #81
CatManD3W
CatManD3W's Avatar
Are those the 17" or 18".....im not sure with that style but I know the 6 spoke and 5 spoke fit the ls400 and tt brakes...not sure about that style
Old 11-20-14, 08:48 AM
  #82
t2d2
t2d2's Avatar
^^^ I was just looking at some listings yesterday and saw those same ones described as 17". Not sure if they are made in multiple sizes, though.
Old 11-20-14, 11:00 AM
  #83
CatManD3W
CatManD3W's Avatar
Either way with those wheels you would want a 15mm spacer in front to make them flush anyways...so they should be fine with the spacer for clearing brakes
Old 11-23-14, 09:12 PM
  #84
GSGenesis
GSGenesis's Avatar
Anyone know if 18" lowenhart LV1's will clear? I through on some 5mm spacers just to test fit and that shi* looked stupid as hell.... If they won't fit it's either ALL MY POLISHING WORK, can't even tell you how many hours... Brand new rotors, pads, RCA's and lines for nothing... Or ditch the wheels.... Dammit I wish I would have perhaps looked into this prior... 😑
Old 11-24-14, 08:42 PM
  #85
3L4jzz31
3L4jzz31's Avatar
Are you doing tt or ls400? I'm assuming the calipers aren't on since you're not sure if they'll fit or not?
As I said in a couple posts higher up check the distance from the end of the backspacing (where the rotor touches the wheel) and approximate where the caliper would meet the back of the face. take the measurement of the "depth" . Also if you're barely clearing SC calipers you'll deff need more than a 5mm spacer.
Old 11-24-14, 10:38 PM
  #86
oldManTan
oldManTan's Avatar
gonna check if 350z wheels fit soon. guy has staggered ones, 7.5 in the front and 8 in the back so hopefully they both fit over the TT brakes. they look deep enough and the spokes look to stick out far enough, kinda similar to my current wheels which clear by miles. i'll report back once i test fit them, and hopefully buy them if they fit. really don't wanna get spacers though so we'll see.
Old 06-10-15, 12:18 PM
  #87
MyGS3
MyGS3's Avatar
Default RX330/350 wheel
I'm looking at purchasing a set of 18" RX 330 wheels for my 2GS. Has anyone had experience with this wheel and the Supra Caliper?
Old 08-24-15, 09:52 PM
  #88
OG Dada
OG Dada's Avatar
Read the whole thread, need to find out if 98 LS wheels will clear my Supra TT brakes? Thanks.
Old 08-25-15, 04:29 PM
  #89
Blkexcoupe
Blkexcoupe's Avatar
I don't know for sure, but I'm going to say no based on the fact that 16" wheels are a pretty tight fit on the LS brakes already. I've seen the wheel weights make contact with the caliper on 16" wheels I've tried (with LS brakes). The supra TT wheels are 17" for the slightly larger diameter of the TT rotor.
Old 12-29-15, 06:22 PM
  #90
TheHerb
TheHerb's Avatar
Default 2008 gs350
Does anyone know if 2008 GS350 wheels will clear the Supra TT brakes. picture available here: http://i1217.photobucket.com/albums/...te/SC300-6.jpg
Quick Reply: List of wheels that fit TT and LS400 BBK
