List of wheels that fit TT and LS400 BBK
Old 11-15-11, 01:23 PM
  #31
ISFFUN
ISFFUN's Avatar
How about 17" IS250/350 wheels with LS400 calipers?
Old 12-03-11, 09:58 PM
  #32
76mmturbo
76mmturbo's Avatar
varrstoen 2.2.1 9.5 +22 fit over ls 400 brakes. I test fitted mine today!
Old 12-03-11, 11:35 PM
  #33
CalitriSC
CalitriSC's Avatar
needed at least a 10mm spacer on my friends SC. could have been bigger
Old 02-06-12, 05:32 PM
  #34
DuWerke
DuWerke's Avatar
Hope this helps.
Originally Posted by VarrsToen
The ES 3.3 and 4.4 will clear the brakes on a +22 offset.
The ES 2.2 will clear at a +12 offset
Old 02-12-12, 08:48 AM
  #35
lookEVO
lookEVO's Avatar
Infiniti M35x (18's) wheels clear LS400 calipers with a 10 mm spacer.
Old 02-12-12, 03:43 PM
  #36
PoGikoSc4
PoGikoSc4's Avatar
Will Supra TT wheels clear LS400 BBK?
Old 02-12-12, 03:54 PM
  #37
SChema
SChema's Avatar
^, Yes.
LS400 calipers are not as wide as TT calipers. You can run CCW Classics on the LS400 without the 5mm spacer required to run with TT Calipers. The LS400 brake caliper and rotor assembly is also a bit smaller in overall diameter when compared to the TT. If wheels fit over TT brakes, threre's no reason they should not clear LS400's.
Old 03-04-12, 09:14 PM
  #38
SFrymyah
SFrymyah's Avatar
18x8.75 +20 XXR 527's clear LS400s by a mile. Pics to prove coming.
Old 03-13-12, 08:13 PM
  #39
2BENVD
2BENVD's Avatar
Not sure if already mentioned but do ruff racing wheels fit?
Old 03-16-12, 12:55 AM
  #40
aristo123
aristo123's Avatar
19x9.5 +22 varrstoen es1.1.2. Will clear by about the thickness of a business card. It's a perfect fit, no shave required. I also know for sure the 5 spoke 18" 3gs wheels fit with no issue. Also the 18" is250 multi spoke wheels fit. The ones that are just straight spokes. I'm not sure about the 5 spoke split 18" isx50 wheels.
Old 03-22-12, 12:32 PM
  #41
speed6
speed6's Avatar
i have xxr wheels 526 18x8.5 +35 fronts and 18x9.5 +35 rears, and they clear the LS400 bbk with ease. My supra ones (17x8 17x9.5) have less clearance, but fit just fine. They fit pretty flush to the edge, check out the wheel fitment guide.
Old 06-11-12, 11:02 AM
  #42
Glove81
Glove81's Avatar
Was wondering if anyone knew if the 19 inch Infiniti M35S wheels fit over the bbk on 99 ls 400 here is the add for them that is on the cl forums.
https://www.clublexus.com/forums/whe...new-tires.html
Old 07-06-12, 04:58 AM
  #43
bodydrager
bodydrager's Avatar
For those who want to run IS300 wheels you'll need to get 15mm spacers and 50mm extended wheel studs. With this combo there's about 10mm of clearance between the wheel and caliper.
Old 07-28-12, 09:21 AM
  #44
boosted516
boosted516's Avatar
just got the caliper on to realize my xxr 526 10.5 +22 dont fit...wtfff
Old 08-02-12, 01:12 PM
  #45
moosejaw2
moosejaw2's Avatar
Vossen CV3s clear my supra BBK
Quick Reply: List of wheels that fit TT and LS400 BBK
