List of wheels that fit TT and LS400 BBK
Old 08-14-10, 02:17 AM
Kira X
美少女戦士セーラームーン
Kira X's Avatar
The original IS250/IS350 18 inch 5 spoke wheels from 2006 to 2008 should clear the LS400 brake kit, but they will not clear Supra TT brake kit.
Old 01-24-11, 08:52 AM
2JZSoarer
2JZSoarer's Avatar
I know I'm reviving an oooooooold thread. But I am searching through threads to see if IS300 wheels clear LS400 BBK. I guess I'll just do the dirty work and swap to see.
And I also want to contribute that S14 wheels clear the LS BBK.
Old 02-02-11, 09:41 AM
Klaus
Klaus's Avatar
I'll test that theory tonight. About to put my IS350 wheels on my lexus and the supra has it's front wheels off right now. So I'll see if it clears. IS350s have some good sized brakes, I'd be surprised if they don't clear.
Old 02-02-11, 09:46 AM
SChema
SChema's Avatar
Klaus, if you have some spare time while test fitting the IS wheels could you measure the distance from rotor surface to the back of the wheel spokes to give me a rough idea of fitment, in millimeters, if possible?
Thanks, I appreciate it.
Attached is an image of my current set-up.
LS brakes behind Classics. I have about a mm before the wheel touches the caliper closest towards the hub. I'm thinking I may get lucky and the TT caliper will sit further away from the hub, closer towards the area behind the spokes that allow for more clearance. Only reason I may go TT, is I already have a matching pair installed in the rear. I would like to mount them with out the 5mm spacer most have been using, the wheel and tire package is quite aggressive as it is already.
Don't worry those are not dings, dents or cracks in the wheels, just cotton fibers from the wash mitt.
Old 02-03-11, 06:19 AM
Klaus
Klaus's Avatar
Ah well hate to tell you on classics, but when you order classics for a turbo supra they provide a 5mm spacer. The inside edge of the caliper hits. You can also grind down the inside caliper edge just slightly until it clears. A lot of the supra road race guys do this to avoid running spacers. Don't worry, there's PLENTY of meat on those calipers, you won't damage anything. My buddy has been running shaved calipers for probably a solid 2000 road race miles with zero issues.
Also the IS350 wheels have the same issue- they clip the inside edge of the caliper.
Old 02-07-11, 05:08 PM
driftboy
driftboy's Avatar
man I wish I saw this thread before I got my wheels lol o well just got some spacers.
Old 02-08-11, 01:11 PM
dwebb99
dwebb99's Avatar
I run 18" 350z Track wheels (Rays) on my SC with my LS400 BBK, plenty of clearance.
Old 02-08-11, 08:41 PM
SEXC
SEXC's Avatar
I had 17" classics on my supra without spacers. It clear the calipers without any modifications.
Old 02-08-11, 09:15 PM
abounly
abounly's Avatar
The isx50 wheels fit for the ls400 06-08?
The xxr 521s x8.5 +30 do as well
Old 02-10-11, 10:34 AM
t70 supra
t70 supra's Avatar
lowenhart 18x10 +bs5 fit
rota p45R 18x9 +35 fit
rota d2 18x9 +30 fit
Old 10-23-11, 02:15 PM
atx
atx's Avatar
If I want to upgrade my stock SC400 calipers to stock LS400 calipers, what size spacers do I need to make these fit on my stock, aluminum 16" SC wheels?
Old 10-24-11, 11:37 AM
Oxford
Oxford's Avatar
Rota SVN-R 18x10 +30 clears (Fitted with LS brakes not TT)
Old 10-28-11, 12:52 PM
One HoT
One HoT's Avatar
tired sc430 it does not fit....i have g35 rays 19 inch wheel as a spare..
Old 11-03-11, 01:05 PM
JDMJoe239
JDMJoe239's Avatar
how about enkei RP03's? i might be going to get some ls400 brakes tomorrow at the junk yard and i want to know if it will fit before i buy them. i have a little over an inch and a half clearance with the stock sc300 brakes.
Old 11-13-11, 01:10 PM
MrSlopra
MrSlopra's Avatar
Stock 94-96 Dodge Stealth wheels fit the LS400 brakes and I'm sure the TT brakes for anybody who needs a cheap wheel set up/spares/drift wheels
Anybody fit 18" BBS LM with the LS400 brakes before?
Quick Reply: List of wheels that fit TT and LS400 BBK
