need help asap
Old 03-06-10, 12:35 PM
otis_jzs
otis_jzs's Avatar
Default need help asap
Ok so I was going to pick up an ls400 bbk and om my way there the guy calls me says there 2 piston not 4 and I know what I need to do the 4 piston set up what what do I nned to do the 2 piston? Is it the same process? And will I be able to upgrade from the 2 to the 4 later on? Please help asap I need to know because only the back brakes are working on mt
Y car right now. PLEASE HELP ME. THANK YOU!!!
Old 03-06-10, 01:53 PM
GSteg
GSteg's Avatar
If they're 2-pistons, they're from the 90-94 LS400. Its a downgrade from the OEM GS setup.
There are plenty of threads on here that discussion the involvement in swapping to a 4 piston setup.
Old 03-06-10, 02:29 PM
otis_jzs
otis_jzs's Avatar
Yes I know that I was supposed to get a set of 4 pistions but it turns out there 2 piston and I need brkes horribly and the 2 pistion set up is cheaper then gs brakes so I need to know the answeres to the questions up there ^^
Old 03-06-10, 02:45 PM
GSteg
GSteg's Avatar
If you want to convert to the LS400 (4 pistons) later, you're going to obviously need the caliper and the 12.4" rotors that comes with it. You'll either need to shave off some of the tie rod bolt or get some sort of Roll Center Adapter to clear the calipers.
Second thing is the clearance from the wheels to the brake. If you're on stock wheels, you'll need 15mm spacers. If you have aftermarket wheels, then you may or may not spacers depending on the disk.
Third of all, you'll need to either bend the dust shield, or trim some parts off to accomodate the larger rotors.
Other than these two issues, it's pretty much a direct swap.
Old 03-06-10, 03:03 PM
otis_jzs
otis_jzs's Avatar
Ok. So what would I need to do. The 2 piston for now?
Old 03-06-10, 03:09 PM
GSteg
GSteg's Avatar
yes. If you must have some kind of braking right now, just get the 2-pistons as a temporary solution until you get the 4-pistons.
Old 03-06-10, 04:29 PM
otis_jzs
otis_jzs's Avatar
So I need the rotors calipers caliper brackets pads. Anything else? And do you know i f I'm still going to need the spacer with the 2 piston?
Old 03-06-10, 06:07 PM
GSteg
GSteg's Avatar
No spacers needed. You only need them for the 4-pistons calipers.
Old 03-13-10, 07:09 PM
pwesseler
pwesseler's Avatar
what was the end result of this thread?
Old 05-01-10, 10:43 AM
BIGVIC23
BIGVIC23's Avatar
bump...GETU1.. what happened.....update?
DreaMzZ
Suspension and Brakes
41
04-03-23 05:17 PM
SC400R1
03-11-09 08:01 AM
NAZTY97
08-16-04 10:21 AM
rajah996
Southeast
11-27-03 05:16 AM
Quick Reply: need help asap
