Brake pads for 07 IS350
I need some front brake pads (original pads the dusty ones) and cabin air filter. Where could I get these for the least amount of $. Please post some part numbers if you guys can. Thanks in advance.
here are your dusty pads part number 04465-30410. dunno the cabin filter. u can get a set of the pads from sewell lexus. enter "clublexus" for a 10% discount. sewell has super good service and fast on shipping stuff out.
Tech Info Resource
Here is best deal i think Duralast Gold C'Max
Full Ceramic
less noise
Longer Life than OEM
Causes Less Rotor wear
And best thing When they wear out just take them Back to any autozone and they will give you new ones at no cost. as long as you own the car.
http://www.autozone.com/autozone/cat...&parentId=44-0
Full Ceramic
less noise
Yeah, I also need new brakes for my 2007 IS350.
I've been searching for some non-OEM brake pads on the site, but haven't really found them. I know they have to be out there and ebay pads just seem to cheap to be good.
I'd go OEM too if that's the best route. Sounds like you need:
1) front and rear pads
2) greece
3) shims
Any idea where I can purchase these online? Is there anything else I'm missing?
2) greece
3) shims
You guys ever heard of this company?
http://www.irontoad.com/l_home.htm
I dunno, also sounds too good to be true.
Are you sure you need rear pads? it's unusual for the rears to wear out in anywhere near the amount of time the fronts do
Tech Info Resource
I was also going to go ahead and get cabin/oil filter, as well as a new oil drain plug gasket (if you think I'll need it).
irontoad I don't see having the shims though, or the grease. That sucks. Where can I get this stuff without going to the stealership. I need my 45,000 mile service on top of the pads, so that's why I'm buying all this stuff. My friend is a certified tech so I'd rather throw him the loot to do the service than the stealership. They want $184 for an oil change, filter replacement, and a check of my car. Uhm ok!
This is what I'm ordering from irontoad:
87139-YZZ08 Interior cabin a/c filter $20.00
04152-YZZA3 2-wheel drive oil filter kit $4.33
17801-31110 Engine air filter $17.60
04465-30410 Front brake pads $45.00
I think this is all I'll need to replicate a 45,000 mile service. Any other suggestions definitely welcome I'm a newbie owner. I'll throw up pictures of my care soon. I have 20" rims (Konig Unknowns).
Full Ceramic
less noise
Full Ceramic
less noise
If I go with the Duralast Pads... can I buy OEM shims and use them with these pads? do I need the brake disc hardware kit? Please let me know. My rotors arrive on Friday so I want to order this stuff ASAP. Thanks.
