Brake / Rotor Help 911!!! Please help
Old 01-14-10, 05:51 PM
Losaun
Losaun's Avatar
Default Brake / Rotor Help 911!!! Please help
Just got a 2000 GS300 with 85K miles on it to sit right beside my 93 GS Project. Car is perfect but there was a slight shimmy when I applied the breaks. I checked the pads and there were good. I then had the rotors turned and low and behold the shimmy was gone. But now there is a little knocking sound from the passenger side caliper area. I have taken the rotor and caliper of serveral time and inspected but still the same thing. Please help gotta go to work in the morning.
thank you in advance...
Old 01-14-10, 06:13 PM
Losaun
Losaun's Avatar
Bump*** Anyone?
Old 01-14-10, 06:25 PM
UncleRay
UncleRay's Avatar
Check your caliper pins on the sides of the brake pads. One of them should be stuck, or not moving as it should be. Easy fix if you have the right tools. You would need a clamp, a grinder, greese, and something to push this thing back in.
Also, make sure that your rotors are not warped at all. If they are, they'll be needing a change. How to tell? Turn the wheel, look towards the back of the car looking at the top of the rotor. If it looks crooked, change it.
This is an infamous thing with the GS's
Old 01-16-10, 11:45 AM
Losaun
Losaun's Avatar
Thank you UncleRay, I really appreciate it..... I let you know what happens...
Wingnutt92
04-09-18 01:35 PM
saleen90
03-17-13 04:20 PM
windex
Suspension and Brakes
05-27-09 07:27 PM
ginjuice
08-28-06 01:18 AM
elclassico
45
01-10-03 01:55 AM
Quick Reply: Brake / Rotor Help 911!!! Please help
