installing springs
Old 01-08-10, 08:48 AM
HeartmyIS
HeartmyIS's Avatar
Originally Posted by JoshIS408
If you install springs correctly, they don't settle.
I thought all springs settle? Before springs are installed/unused they expand due to no weight being on them. So after installing, the car's weight and driving motion compresses the springs to their prescribed height. Would this be referred to as "break in/settle"? I mean even after installation, it will take the springs to set properly with the car's weight on them right? I don't think the springs will stay expanded (at their unused dimension) withe a few thousand pounds on them. Correct me if I'm wrong, I'm still new to the whole lowering thing =)
Old 01-08-10, 08:56 AM
Phil888
Phil888's Avatar
Seriously install the springs anytime will be alrite, unless you live in a snowy area! lolz.. Dont worry about the springs settle cause the car(springs) will do its job no matter what. best thing to do, is to push the car on each side when the springs are installed to make sure they are in place. if you know what i mean. Or just pack 5 ppl in the car and allow more pressure on it lolz.. Most likely, it'll settle in 2 days or so. GL
Old 01-08-10, 09:03 AM
HeartmyIS
HeartmyIS's Avatar
Thanks, will probably install the springs after coming back from the snow
Old 01-08-10, 09:22 AM
Kurtz
Kurtz's Avatar
Springs do not settle.
Bushings can deform if the springs aren't installed correctly though.
Old 01-08-10, 09:25 AM
IS-SV
IS-SV's Avatar
After reading this thread, my preference still is to get these springs installed correctly by an experienced shop. I'd recommend, keep looking until you find that shop.
Old 01-08-10, 09:35 AM
dojoman
dojoman's Avatar
Yep they don't settle. My F-sport springs are exact height from day 1 to now.
Old 01-08-10, 09:43 AM
IS-SV
IS-SV's Avatar
No settling on my Eibach 350's installed in May 2009.
Old 01-08-10, 05:15 PM
xuningshen
xuningshen's Avatar
anytime you lift up your car to do anything to it, and lower your car back down, your car will be higher because the suspension was fully unloaded, after you drive the car enough so the wheel turns a full round it goes back down to normal ride height.
i think thats why people sometimes confuse springs w/ "settling" after doing an install because really when they drop the car off the jack they're seeing the ride height with the suspension all propped up from being lifted
Old 01-08-10, 06:46 PM
KangstaxD
KangstaxD's Avatar
hey so my if my friend is confident, I think we should proceed ...
Old 01-08-10, 07:04 PM
Mv350
Mv350's Avatar
its not that bad, just take your time, and dont rush, trust me,i lifted my truck myself, and i lowered this car myself. just takes time.good luck and be careful.
Old 01-08-10, 08:50 PM
KangstaxD
KangstaxD's Avatar
Thanks mv350 haha... Well I don't know what to expect but hope I don't lose a finger =(
bjdealer
NX - 1st Gen (2015-2021)
05-17-18 08:52 AM
chinaxb0y
03-05-10 10:29 PM
FRANK!!
Suspension and Brakes
14
07-28-08 09:47 PM
Kan-O-Z
10-29-06 09:00 PM
Expresso1
09-06-05 12:23 PM
Quick Reply: installing springs
