Can't adjust my ride height with my coilovers
I tried to adjust one of my new coilovers (megan) today and could not move the post. I loosened the bottom nut and grabbed hold of the thread bar (whatever its called) and it won't budge!
The only way it would move is if I adjusted the nut that tightens/loosens the spring...So I ended up tightening the spring nut to get the bar to rise up...
I was under the impression this thread bar should move freely, at least with a good grasp with gloves on!!!
coilover sleeve does not move, the perch does which is what makes it adjustable. there should be 2 perchs. one turns one way and the other turns the opposite. you need to loose the bottom one and spin it down towards the bottom. then you can adjust the top perch to where ever you want. once you have it where you want it, you spin the bottom perch back up to meet the top perch and tighten them both.
That's crazy talk.
Adjusting the spring perch collars changes your spring Pre load and should NOT be used to adjust ride height.
the double "collars" that are holding the spring in place should not be adjusted once you lock them together. (double lock nut kinda deal)
To adjust your ride height, you loosen the collar near the bottom of the coilover. Spin it up and out of the way.
Then, with your spanner wrenches.. grab one of the collars that sit underneath the springs and use that to thread IN (lower) or OUT (raise) the coilover body. These should turn WITH the coilover body.. if they spin by themselves they aren't locked together tight enough. (or you grabbed the wrong collar to spin)
EDIT: to lower the car, put the wrench on the top collar and spin it clockwise
to raise the car, grab the bottom collar and spin it counterclockwise
If you still can't get it to turn, get some PB blaster and go to the gym.
I recommend putting some kind of antiseize on them too.
Spring preload should be zero. To acheive zero preload, the spring perch collars should just come up to the spring. Do not compress the spring with the collars. You should *almost* be able to spin the spring with the spring perch collars tightened together.
That's crazy talk.
That's crazy talk.
My suggestion to you if you having problems with this is to immediately seek a professional to give you direction, face to face.
Righty tighty (car higher)/lefty loosey (car lower)
Soak it in PB blaster. and then after you get it loose, put some antisieze on the threads.
dirt can get inbetween the threads and make it really tight. Get a rubber mallet and tap the end of the spanner wrenches to help loosen it up.
It may be all the way lowered already?
