Front clunking noise Gs400
Old 10-29-09, 10:38 PM
maxim240sx
maxim240sx's Avatar
Default Front clunking noise Gs400
2000 Gs400 with 140k.Ok so I've searched all over about this noise. I replaced my front struts last month. Have also replaced the BJ's recently. Right after the strut install I get this clunking noise from the driverside. When I replaced the struts the factory built in "bumpstop" that is inside the dust boot was deteriorated. But it was a saturday and the part store didn't have anything in stock and I had to get to work monday morning, so I just slapped it all back together.
Question is replacing this bumpstop/dust boot thing gonna stop the noise?
Because I wasn't getting the noise before I removed the old struts.
Also has anyone bought these KYB strut boots and solved any noise issues?
http://www.carpartsdiscount.com/auto...ml?3593=122719
Or should I spend the extra $$ at sewell on OEM?
I read several threads about strut mounts, but mine were fine, just not the "bumpstops"
Thanks for any info
Old 10-30-09, 01:00 AM
Red Bully
Red Bully's Avatar
I think you due for some upper control arms. Just picked mine still have to put them in ($414 a side). Iam haveing the same problem i changed the shocks and balljoints and bushings.
Old 10-30-09, 02:19 AM
ivnnln
ivnnln's Avatar
I just finished mine tonight, upper control arms, caster arms, steering rack bushing, and Tein High Tech spring. I got no more clucking noise. Also, I changed all four struts to KYB G2. If you changed the lower ball joints, then do the caster arms too. I changed my ball joints along with outer tie rods a few months back before I got all these done today. No more vibrating at 60 or 100mph. All I need is the aligment tomorrow. Try to get a new strut bumpers, if you need KYB G2. It is recommended on this vehicle. If I were you, I would start with new strut bumpers, new KYB G2, lower ball joints, and caster arms. Those parts are not really expensive like the upper control arms, and take it from there to see if you still have a clucking noise. Good luck. Shoot me a lines if you need help. Good luck.
Old 10-30-09, 12:34 PM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
Check out this thread that explains the ball joints and clunking issues.. Really made sense.. GL..
https://www.clublexus.com/forums/sus...and-facts.html
Old 10-30-09, 09:43 PM
maxim240sx
maxim240sx's Avatar
I think I'll start with the strut bumpers this weekend. I have already replaced the lower ball joints. Does daizen make a caster arm bushing? I was planning on ordering their steering rack and swaybar kit soon too
Red bully- why are you replacing your upper control arms? I mean how can they go bad, besides the bushings themselves?
Old 10-30-09, 10:02 PM
Red Bully
Red Bully's Avatar
The upper control arms have ball joints built in to them, over time they wear out i have 106k on my car now. and you dont want them to fail when your doing 60mph
Old 10-30-09, 10:14 PM
maxim240sx
maxim240sx's Avatar
That does make sense lol. Thanks for the info everyone
Old 10-31-09, 10:23 PM
RUSSOM
RUSSOM's Avatar
I've seen the SPC UCA. How is their long term durability? As good as the factory Toyota part? I know its a performance replacement, but that doesn't nec. mean it will last longer.
Thanks
Old 11-30-09, 11:56 AM
Rippaflow
Rippaflow's Avatar
Does anyone know where I can buy just one side?
tonyjh63
RX - 1st Gen (1999-2003)
04-05-14 08:30 AM
arlink70
11-01-06 07:45 PM
642jdub
05-09-04 09:38 AM
bigsax
01-23-04 09:53 AM
Quick Reply: Front clunking noise Gs400
