BCR Coils....
Old 08-21-09, 01:39 PM
eklikewhoa
eklikewhoa's Avatar
Default BCR Coils....
Just recieved my set of BC coilovers from CMS and will be installing them on my '01 GS3. Hopefully all goes well I will be adding pictures to the "Non-Air" DUMPED thread!
Replacing H&R springs on stockies for this set up and with the 20x8.5/20x10 hopefully it tucks.
Old 09-04-09, 06:53 PM
GSJake
GSJake's Avatar
How have these been? I know its only been like 2 weeks but any feedback??
Thanks!
Old 09-05-09, 04:50 PM
CircuitMS
CircuitMS's Avatar
Hey glad we could get these for you so quickly!
How are you liking them?
Old 09-10-09, 05:58 AM
eklikewhoa
eklikewhoa's Avatar
Lovin them!
Was able to dump the car and not sacrafice strut piston travel and the ride is NICE!
Here are some shots when I finished the install.....
Old 09-10-09, 09:34 AM
GSJake
GSJake's Avatar
Looks Great! What type of mounts do you go with? Rubber?
Old 09-10-09, 12:02 PM
StayBroke
StayBroke's Avatar
Originally Posted by eklikewhoa
Lovin them!
Damn that's G'd up...
Old 09-11-09, 06:30 AM
eklikewhoa
eklikewhoa's Avatar
Thanks guys.
The mounts are aluminum or whatever metal it comes in... There was no other option I believe for the 2nd gen.
Old 09-11-09, 09:03 AM
GSJake
GSJake's Avatar
I believe thay come in a pillow ball mount (what you have) but then there is a rubber mount option as well. Can anyone confirm?
Old 09-11-09, 09:25 AM
juice14
juice14's Avatar
for the IS350 they have both pillowball and rubber, im guessing it should be the same for this car
Old 09-11-09, 04:55 PM
FIGS
The Maker
FIGS's Avatar
you should be able to get them with rubber mounts. There is no reason to pillowballs on a non locating portion of the suspension in a double wishbone. You will also need a set of MEGA arms for those rear tires I will be releasing them next week for the 2 GS.
Fig
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old 09-13-09, 01:12 AM
t0ekn3e
t0ekn3e's Avatar
Are you all the way down on the coils for the BCR coilovers? The car looks great!
Old 09-14-09, 03:49 AM
eklikewhoa
eklikewhoa's Avatar
The spring height adjustment is set so the spring sits right against the top mount... meaning I adjusted that ring so when the coilover was sitting in my lap the spring would not move around...under no load.
Most/All of the height adjustment was done at the lower adjustment point (strut body height adjustment). Figured this way the strut piston would be allowed the full travel if needed.
Old 09-14-09, 09:10 AM
Infamous 1
Infamous 1's Avatar
Do you have any fender work done?
Old 09-14-09, 01:10 PM
t0ekn3e
t0ekn3e's Avatar
how much more room do you have for height adjustment with the lower adjustment?
Old 09-18-09, 09:04 PM
eklikewhoa
eklikewhoa's Avatar
I rolled the front and it's fine but going up ramps the steering wheel needs to be straight or it grabs the fenders... probably doesn't help with the wide tires.
The rears I didn't do anything.
The height adjustment for the lower I can probably raise it about 1-2" above the tires?
Quick Reply: BCR Coils....
