DIY brake pad change and recommendation
Old 04-10-02, 10:54 AM
his_eminence
his_eminence's Avatar
Default DIY brake pad change and recommendation
How difficult would it be for me to change my brake pads myself? If it's not too difficult, what brake pads should I go with? Anyone have a favorite to go on the stock brake system? Thanks.
Chris
Old 04-10-02, 02:25 PM
LEXter
LEXter's Avatar
Default .
try the EBC green brake pad....they are awesome
and if u wan go for the bridgestone steel brake lines......
and if u wanna spend more u can change the rotor to a slotted and drilled rotors from power-stop. All these are stock size.
Old 04-16-02, 03:42 PM
gs393
gs393's Avatar
Question brakes
what is EBC brakes and where can i get them ?....are they good brakes for the GS 300 i have a 93 and i have some problems with it squeaking please reply Thanks
Old 05-20-05, 10:08 AM
elclassico
elclassico's Avatar
Default torq wrench
i didnt use any squell greese or a torq wrench? is that a problem?
Old 05-20-05, 12:26 PM
joshoowa
joshoowa's Avatar
torque wrench is optimal so u dont undertighten it and the bolt comes loose. i dont own a torque wrench been using my craftsman socket wrenches to do the job.
grease u want it on the rotor hat so next time it'll be easy to take off..because rust plays a factor in bonding parts together.
Old 05-20-05, 02:41 PM
BA_GS400
BA_GS400's Avatar
I've read other threads here that speak highly of the Axxis brand pads. They do have two kinds though,.....one was liked better than the other.
Old 05-20-05, 02:57 PM
engin_ear
Everything in Moderation
engin_ear's Avatar
EBC Greenstuff recommended. Stock rotors with aftermarket pads - not. Stock rotors can accelerate the wear of a softer aftermarket pad. And certain aftermarket pads can cause accelerated warping of stock rotors due to extra friction and heat.
Pads are not hard to change at all - if you're car savvy. Best to get a DIY manual of some sort to coach you along the first time if you're unfamiliar, or maybe some instructions off the web.
Old 05-23-05, 02:40 AM
GILLEXUS
GILLEXUS's Avatar
Chris
Try CL'S DIY section. There is a good write-up on changing your stock front brake pads.
schwarz
Suspension and Brakes
14
10-04-14 07:46 PM
Jasonx82
05-12-10 12:47 PM
daweeze02
11-14-09 09:39 PM
jgrooms
09-14-07 03:54 PM
is250gurl
09-07-07 09:09 AM
Quick Reply: DIY brake pad change and recommendation
