Brakes dragging after install?
Old 07-06-09, 07:58 AM
Rock-a-Lex
Rock-a-Lex's Avatar
Default Brakes dragging after install?
I just installed new rotors and pads and I feel I am getting a lot of drag and squeel. Even when I accelerate from a standstill I notice I have to gas it a little more than before.
Is it possible that I tightened the two bolts too much on the front calipers (not the bracket bolts; the other ones)? Are they not supposed to be tightened that much?
Any other suggestions?
Old 07-07-09, 10:16 AM
Rock-a-Lex
Rock-a-Lex's Avatar
Nevermind...I think I found what the problem was. Sticking caliper pins. Took them out and re-greased also re-greased the back of the pads and used brake cleaner spray on the rotors while I was in there. Seems to be a lot better but still a squeel every once in a while; perhaps this is common for the first week or so with new rotors and pads.
Old 07-07-09, 01:01 PM
GS300ToM
GS300ToM's Avatar
it shouldnt squeel period... spray some brakeleen on it
Old 07-07-09, 05:54 PM
Rock-a-Lex
Rock-a-Lex's Avatar
What do you mean? Brake parts cleaner spray? If so, I already did that...on the rotor. They are not squeeling loudly like you may think. VERY sporatically and only when I am coasting, never during acceleration or braking.
Old 07-07-09, 06:28 PM
newgsman
newgsman's Avatar
I just did my brakes (new rotors and pads) on the weekend as well. Whenever I do brakes I always put lots of brake-anti-seize compund between all the shims and slider clips and pins. This really helps to prevent squeeling.
In your case if the squealing is occurring even without braking it probably isn't your pads. It could be that you have some debris between the pad and the rotor or it could be that one of your clips got bent and its rubbing against the rotor, or maybe you accidently bent the backing plate/shield and its rubbing. If it is a faint squeal it will probably go away after while (once whatever is rubbing wears out)
Are you sure the noise is not the master cylinder running through its self check cycle?
Old 07-07-09, 08:57 PM
Rock-a-Lex
Rock-a-Lex's Avatar
...Damn, you could be on to something here. I will check it when I get my car back from the bodyshop this weekend. I am getting some aero goodies installed.
Thanks again for the insight.
Old 07-08-09, 02:01 AM
ItsChris
ItsChris's Avatar
check your e-brake adjustment, make sure the pads are not too tight. I had to readjust my passenger rear because I found out whoever adjust them before me, pretty much left the adjustment so tight the pads where still grabbing on to the rotor hat when i was driving without the e-brake engaged. After I adjusted it, the car actually moves ! hahah
Old 07-08-09, 05:55 AM
Rock-a-Lex
Rock-a-Lex's Avatar
I just researched these areas that will need inspecting:
- Re-adjust parking brake
- Inspect and grind down as necessary any parts hitting rotor
When I get my car back I will check these things out...this should do it!
Thanks again!!!
Old 07-08-09, 06:46 AM
adamgamz
adamgamz's Avatar
I have been having the same issue since installing my LS400 calipers / pads / rotors. It seems to be getting better as I drive, I was thinking maybe the piston in the caliper was sticking, but I might try to grease up the pins as you didwhen I get time to take it apart again. PITA.
Old 07-08-09, 03:51 PM
jspecdan
jspecdan's Avatar
rock-a-lex, what kind of pads did you get?
Old 07-09-09, 08:22 AM
Rock-a-Lex
Rock-a-Lex's Avatar
Akebono ProAct ceramics.
Old 07-09-09, 10:36 AM
GS4_Fiend
GS4_Fiend's Avatar
You need to readjust the parking brake.
Old 07-09-09, 06:42 PM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
Will this have a effect on the rear only or front brakes as well.. Thanks
Old 07-10-09, 01:00 PM
Rock-a-Lex
Rock-a-Lex's Avatar
Actually, I'm not too sure of this either. I want to say that it will just effect the rears but i am not familiar at all with the e-brake portion on any car. Something I have to research more and adjust myself if necessary.
Can anyone else provide input?
Old 07-10-09, 02:01 PM
GS4_Fiend
GS4_Fiend's Avatar
The splash guard for the rotors might be touching the rotors.
Quick Reply: Brakes dragging after install?
