The Battle of the Chassis Braces!!
Old 06-29-09, 10:02 AM
JDKane527
JDKane527's Avatar
Default The Battle of the Chassis Braces!!
So...like the subject says. Since the F-Sport chassis brace came out, more people have been getting that than the Tom's or Jun chassis braces. First off, F-Sport is cheapest of the bunch, but which is the best complement to the car for handling? Although, since the F-Sport line came out, seems like less people have been getting chassis braces in general. I would think of getting it to help in balancing the weight, Front and Rear, and to help in handling. Correct me if I'm wrong though, but this thread is for people to post their experiences with the different braces and to compare the three!
Tom's Rear Chassis Brace $552.00
Jun-TW Rear Chassis Brace $563.87
F-Sport Rear Chassis Brace $255.00
Old 06-29-09, 10:08 AM
Kurtz
Kurtz's Avatar
Unless you're on a track, on properly adjusted coilovers, on slicks, none of them is likely to make a measurable difference.
I'm sure you'll get several "feel" replies... I doubt you'll get any that showed a real, measured, improvement of any kind though in street use.
Old 06-29-09, 03:08 PM
ndk83
ndk83's Avatar
Btw listen to Kurtz he tends to know what he is talkin about,
and to add one more comment to his, these chassis braces also add more weight to your car
Old 06-29-09, 07:16 PM
Phiber
Phiber's Avatar
I don't see why coilovers wouldn't make a difference on the street.. are you comparing coilovers vs stock or coilovers vs aftermarket springs?
Old 06-29-09, 07:41 PM
Kurtz
Kurtz's Avatar
Uh, I wasn't commenting on coilovers at all.
I was commenting on all the other things you'd need to do to the car first before you'd have any chance of measuring any effect from a chassis brace.
Old 06-29-09, 07:56 PM
mikes rx
I use "..." ....... a lot
mikes rx's Avatar
I have the F-sport brace, and I will agree with Kurtz's statement.
The overall rear feel is a little tighter, but I honestly don't think it's worth the $300+ new (not considering the massive GB that sewell has).
BTW, no measurements here. And, yes, a feel could be good in one situation but make things worse depending on condition.
Old 06-30-09, 07:52 AM
edwin907
edwin907's Avatar
I drove/rode in a very nice IS250 with JIC coilovers, PS2s, F-Sport sways, immediately before and after installation of the F-Sport brace and the impression is that the rear felt just perceptively more "planted". The difference was very sllight, but it was tighter on switchbacks.
A minor incremental improvement for sure, but with all the above components that IS has superlative handling.
This is exactly the setup I'm installing on my IS350 (if I ever get a day off!).
Old 06-30-09, 08:59 AM
Gernby
Gernby's Avatar
It's funny how so many people say that the braces make the rear feel more planted. Why would anyone want to make a car that has such massive understeer have even more? What we need is something that makes the FRONT more planted so it doesn't handle like such a turd.
Old 06-30-09, 09:21 AM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,845 Likes on 2,332 Posts
This is the truth. The rear of the car is already stuck like glue. It's the front that plows like an agricultural implement. If there were a magic way to move 100 lbs from the front or at least move it from front to back, the car would truly be FAR better. The saddest truth is the IS-F is even worse for weight distribution, but thankfully the suspension is enough better that it doesn't plow nearly as bad as the ISx50. Here's the bad news for the F:
Old 06-30-09, 10:04 AM
mikes rx
mikes rx's Avatar
Wow....I didn't know the IS-F was out 15 years ago.......it's a classic now
Seriously, though, in my opinion the rear being planted helps give a better feel when hitting bumps mid turn, compared to other cars I drive (ie- trucks/mustangs/other solid rear axle vehicles) where the rear end seems to bounce and knock the car off track in the middle of a turn.
Obviously, IRS vs solid rear will make a bigger difference than the brace though.
Old 06-30-09, 11:33 AM
Gernby
Gernby's Avatar
In my experience, most of the performance oriented tradeoffs in suspension tuning do result in poor feel over bumps regardless of whether the vehicle is turning or going straight.
Old 06-30-09, 01:28 PM
HKS350
HKS350's Avatar
LOL...Time for a software upgrade? Maybe? That weight is sad! This explains why none of my coilovers are at the same adjustment in height. I thought is was due to diff. sag rates but its the extra 50lbs on the left rear.
Old 06-30-09, 01:37 PM
flowrider
flowrider's Avatar
Received 1,826 Likes on 1,288 Posts
A 243lb driver driver And he can fit in an IS
Lou
Old 06-30-09, 02:07 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Lou
Why yes, I can. With a helmet even. When you spread it out over 6' 2" it's not so bad. I'm also working on that project. Down to 224 this morning, and still about 50 lbs to go. It might take a minute or two.
Old 06-30-09, 02:12 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Apparently no one has bothered to set the date and time on the scale at Roebling Road. It was actually about 11:30 am on May 2nd, 2009. I'll have to see if I can set it right when I go back in November.
Quick Reply: The Battle of the Chassis Braces!!
