Help! Tein HA installation
Old 03-07-02, 03:27 AM
Shinchan
Shinchan's Avatar
Unhappy Help! Tein HA installation
HI Everyone,
Anyone with Tein HA help.. I had the Tein HA installed yesterday. However, it does look right.
I want about 1" between my wheel and fender all arround. So the installer move up the front rings all the way up.. with 5 thread count from top left. The car did not have any gap... and the moving of the rings upward for the front.
The back is even worse. Installer move the rings all the way to the bottom. The lowest it will go. The gap in the back is F%%k up. Its about 1.5" or more between wheel and body.
Can some help? I think there are two size of the main spring. The installer put the smaller main spring in the front. And Bigger main spring in the back. I think its reverse. Can someone check?
Also on the driver side rear strut. The **** is f&&k up. I turn the **** counter clockwise. to reset to softest setting.. and it continue to turn and turn.. which is different than the other three. The other three strut will eventually hit a place where you can turn no more... DO I also have a bad strut? 'cause right now I can't tell what setting its on...
Old 03-07-02, 03:28 AM
Shinchan
Shinchan's Avatar
Oops.. I mean:
Anyone with Tein HA help.. I had the Tein HA installed yesterday. However, it does not look right.
Old 03-07-02, 09:14 AM
LexusRules
LexusRules's Avatar
sounds like he made a very big mistake man! my car is set almost to the highest on the rear and front and there is only like 1" wheel gap
Old 03-07-02, 09:25 AM
Shinchan
Shinchan's Avatar
Does anyone know if the Front Main Spring are suppose be bigger than the Rear Main Spring?
Old 03-07-02, 09:29 AM
LexusRules
LexusRules's Avatar
i dont see how he could make such a big mistake.. yes they are different
Old 03-07-02, 10:46 AM
QBranchCars
QBranchCars's Avatar
Default Re: Help! Tein HA installation
Sounds like it's bad.
Good luck.
Old 03-07-02, 11:13 AM
Shinchan
Shinchan's Avatar
Hi QBranchCars,
Do you know if your front main spring is bigger than the back?
RI-Lex
Suspension and Brakes
08-13-09 03:12 AM
TomLee
04-08-09 09:21 PM
nysupraman
12
11-19-08 09:58 AM
xBlkGs430x
03-10-07 09:19 AM
Lexus GS3
03-03-05 01:03 PM
Quick Reply: Help! Tein HA installation
