whaaaa?? es300 calipers on my sc300!??!
Old 02-27-09, 05:29 PM
XS_SC300
XS_SC300's Avatar
Default whaaaa?? es300 calipers on my sc300!??!
so i go into the shop to replace my rotors, and this is what they tell me. The rotors won't fit because the calipers are too small. and that the whole brake system is off of a ES300... WHAA?!?!?... how could this happen!!
Old 02-27-09, 05:30 PM
JspecSC3
JspecSC3's Avatar
I dont know. Why dont you post a few pics so we can confirm.
Old 02-27-09, 05:38 PM
XS_SC300
XS_SC300's Avatar
i'll take some pics tomorrow when it's light outside, if it doesn't snow. Hopefully it's just the calipers and not the hub and piston....
Old 02-27-09, 06:27 PM
SC300MO
SC300MO's Avatar
Id think (without seeing pics) that someone ordered up some SC400 rotors for your car...I don't think that calipers off of an ES would mount up to the SC hubs(if memory serves me the caliper mounting bolt holes are different location on SC vs ES)...or possibly that they ordered rotors for a 99-00 sc300(same as earlier SC400 IIRC).
Hope that helps
Old 02-27-09, 10:19 PM
drft_n_sc
drft_n_sc's Avatar
where did you take your car?
it seems a bit awkward that right off the bat they were able to determine they were an ES setup ...
i would get a second opinion before i jumped to the conclusion that you have ES brakes ...
Old 02-28-09, 07:24 PM
XS_SC300
XS_SC300's Avatar
went to a 2nd shop today to confirm, and they also said that it's the bwole brake system that's wrong, they said i have everything from the hub, to the calipers from an es300... i don't know how this could've happened. i'll take the car to lexus to tripple check on moday but so far it's an es300 system, i don't know how this would've happened i even checked carfax for all the records and nothing that extensive was ever done on this car.
Old 02-28-09, 08:13 PM
Luxor
Luxor's Avatar
need pictures
Old 02-28-09, 08:25 PM
XS_SC300
XS_SC300's Avatar
it ended up snowing, and the garage light isn't good enough for good pics, will try on a sunny day
Old 03-01-09, 05:33 AM
rawdil49
rawdil49's Avatar
sounds like a good time to upgrade to supra or ls400 brakes.
Old 03-01-09, 06:48 PM
PecosBill
PecosBill's Avatar
more like the perfect time, no point in getting brand new SC brakes if youre just gonna upgrade later
Old 03-02-09, 01:44 PM
XS_SC300
XS_SC300's Avatar
i need everything from the hub thru all the way to the pads, how much is that gonna run me for the parts? anyone have a ball park cost?
Old 03-02-09, 07:17 PM
itazura
itazura's Avatar
still need pictures.....
Old 03-02-09, 09:37 PM
felixsc300
felixsc300's Avatar
Go to the Lexus dealership to confirm it's actually a brake system off of a ES300.
If it is, then this is really weird...
Old 03-03-09, 12:07 AM
Ryeno
Banned
Ryeno's Avatar
Get some pictures with the wheel off and find the part number on the brake caliper. I HIGHLY doubt you have es300 braking parts on your car.
On a personal note when you go to a shop and have no idea about parts or your car, they are gonna hussle you big time. (like being told you have es300 braking equipment)
Old 03-03-09, 01:42 AM
SC300MO
SC300MO's Avatar
There is no way that any ES300 braking parts are on your car, different suspension designs between the two(macphereson strut on ES vs. double wishbone style on SC), not to mention the hub on an ES300 will be vastly different than SC equipment due to the front-wheel-drive setup on the ES.
Sounds to me you need to check into some different mechanics(you're 2 for 2 on the shady-shop-o-meter in my opinion); Not to mention if these "mechanics" truely cannot tell the difference between a Front-drive hub and the front hub on a rear wheel drive car, I would be VERY hesitant to have them performing ANY work on my car, let alone something as important as brake system work.
*Any Lexus guru's feel free to correct me if anything I have said is incorrect since I haven't looked at an ES300 and an SC300 side by side to compare suspension designs.
Quick Reply: whaaaa?? es300 calipers on my sc300!??!
