does the brake fluid in the reservoir flow into the brake line and vice versa?
Old 02-16-09, 07:06 PM
ToyotaLexus
ToyotaLexus's Avatar
Default does the brake fluid in the reservoir flow into the brake line and vice versa?
it's about time for me to do a brake fluid flush... but I was looking at the
fluid inside the reservoir. it's just as clean and clear as the new brake
fluid I bought today...???
Old 02-16-09, 07:46 PM
kamlung
kamlung's Avatar
how many miles on the fluid??? i wouldn't go by the color of the fluid because normally brake fluid goes bad because it attracts moisture through the hoses... and well, water is clear too... so this means that if you live in an area that is very humid, you should change out your fluid more often... it isn't an expensive job or time consuming... just need a buddy to help you out... i usually do it every year after the first 30k miles...
RageRacerM
Suspension and Brakes
11-20-18 08:05 AM
matts6887
RX - 1st Gen (1999-2003)
20
04-19-16 06:40 PM
Loyalone72
12-24-13 10:55 AM
johnp
Maintenance
15
09-27-02 10:49 PM
Quick Reply: does the brake fluid in the reservoir flow into the brake line and vice versa?
