Sway bar install question
01-27-09, 07:01 PM
I was going to start my rear Daizen sway bar install today... I unbolted the passenger side bushing clamp--no problem...then I went to unbolt the OEM sway bar from what I think is the end link (one bolt), and once it loosened it just kept turning and turning but not coming apart. I see only smooth surface on the other side, so I can't grab it from behind too. What am I missing?
01-27-09, 08:03 PM
Insert an allen key at the end of the endlink bolt. I think it was 4-4.5mm? . Most people dont see it. Use the key to hold it while using an open end wrench to unloosen the nut.
01-27-09, 11:48 PM
that or if u got room, use a vice grip to hold the inside of the end link, probably not the best, but it works too. just be careful the vice grip is on tight and u dont end up stripping it.
01-28-09, 03:50 AM
I'll give that a try tonight--thanks! Mine must be filled with salt.
NikonGuy
04-21-16 07:43 PM
VTsuckah
02-13-15 06:44 AM
Frankdorn
Suspension and Brakes
02-07-09 06:59 PM
fnutz
01-29-06 12:44 AM
TexasGS
33
11-01-05 03:49 PM
allen,
bar,
club,
end,
g35,
gs,
install,
installing,
is350,
key,
lexus,
link,
links,
sway
