Need a new Brake Master cylinder, which one to get??
My Master Cylinder is officially dead and I need to get a new one. I have a 95 Sc with the 2 bolt design and I have upgraded LS brakes up front and stock SC rears. Should I consider the TT Master cylinder or should I just get a stock replacement? Which one would better compensate for my brake bias. Rememeber, I have stock SC rear brakes.
thanks!!
thanks!!
I'm running LS fronts with stock rears and the master is handling quite well, I have noticed a slight bias change; not enough for me to upgrade until I do rears as well.
As far as the research I have done, the 97'+ TT master cylinder is not really an upgrade. It has the same 11/16th inch bore which is the same as ours. The upgrade would be using one out of a 93.5' - 95', which has the 1 inch bore; which I'll eventually do down the road.
